Boost your productivity wherever your work takes you with the executive-class, full-sized the HP Elite x2 1012 G1 Advanced Keyboard.
Full-speed productivity
Enjoy easy, accurate content creation and quick data entry on a stable, full-sized backlit keyboard and touchpad with thin and light scissor keys that have 1.5 mm travel for an efficient, professional user experience. -
Sleek, durable, and comfortable
Resist wear and tear with a sturdy design and DuraKeys coating that help protect the screen when you fold the keyboard into the tablet and cue battery-saving mode. Carry comfortably with the microfiber exterior and use the side loop to hold your pen. -
Enhanced security
Get an extra layer of data protection with integrated NFC technology and a slot for your smart card.
- HP Advanced - keyboard - with NFC - dark grey
- Keyboard
- Interface
- Dock
- Built-in Devices
- NFC
- Security Devices
- Smart card reader
- Dark grey
- 30 cm x 21.93 cm x 0.865 cm
- 450 g
- Designed For
- Elite x2 1012 G1, 1012 G2; EliteBook x360 1012 G2 Notebook
- Keyboard
- Interface
- Dock
Input Device
- Security Devices
- Smart card reader
- Built-in Devices
- NFC
- 30 cm
- 21.93 cm
- 0.865 cm
- 450 g
- Dock
- Dark grey
- -15 °C
- 55 °C
- 10 - 90%
- Designed For
- HP Elite x2 1012 G1, 1012 G2 , HP EliteBook x360 1012 G2 Notebook
