Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
Easy to use
Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection. -
Power up wherever you work
Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending. -
World-class support
Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
- HP Smart - power adapter - 65 Watt
- Power adapter - external
- 280 g
- Localisation
- English / United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- 10.6 cm x 4.7 cm x 2.8 cm
- 1-year warranty
- Localisation
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- MTBF
- 200,000 hours
- FCC Class B certified, CISPR 22 Class B, cUL, EN 60950, IEC950, NOM, UL 1950, EN55022 Class B
- Limited warranty - replacement - 1 year
- 0 °C
- 40 °C
- 20 - 80%
- 10.6 cm
- 4.7 cm
- 2.8 cm
- 280 g
