Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C G2 Power Adapter.
Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Easy to carry and store
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it. -
World-class support
Rest easy with a one-year limited warranty.
- HP USB-C G2 - power adapter - 45 Watt
- Power adapter - external
- Localisation
- English / United Kingdom
- Input Voltage
- AC
- Power Capacity
- 45 Watt
- Input Connectors
- 24 pin USB-C
- 6.2 cm x 6.2 cm x 2.85 cm
- 1-year warranty
- Localisation
- Input Voltage
- AC
- Input Connectors
- 24 pin USB-C
- Power Capacity
- 45 Watt
- Limited warranty - 1 year
- 6.2 cm
- 6.2 cm
- 2.85 cm
