Designed to securely store and charge notebook PCs-from minis up to a 15.6 screen size-inside the classroom, these innovative carts have a large compartment with up to 30 individual, smooth-edged shelves for easy, quick, and safe loading and unloading by teachers and students, and a separate, locked IT compartment to store notebook power adapters (Charging and Managed Charging Carts) and Ethernet connectors (Managed Charging Carts). The HP 30-Notebook Managed Charging Cart stores and charges 30 units and include Ethernet cables for convenient batch installation of software updates or virus protection.
Open architecture
Compatible with a large variety of HP and non-HP notebooks, up to 15.6-inch screen size -
Smart Charging technology
Load-sensing technology directs charging power when and where it's needed most, so each notebook is charged as quickly as possible. -
Retractable front doors
Two locking, hinged front doors on the notebook bay open from the center and retract into the cart's side channels for neat storage. -
Removable shelves
Lightweight, shelves feature hand cut-outs for easy notebook removal and venting for optimal cooling/airflow. Removable shelves and pegs allow extra storage space inside the cart. Shelf insertion/removal is done through a simple peg and notch system. -
Ample ventilation
On the Charging Cart, two continuous-operation fans provide cooling in the top compartment. On the Managed Charging Carts, two fans cool IT equipment located in the top compartment and four fans cool the notebooks in the main body of the cart. All fans are always on. Venting is located on both end panels and the front and rear of the cart. -
Casters
Four 4-inch medical-grade, dual-wheel custom casters support easy turning and moving over thresholds. All four casters can be locked into place through a foot brake pedal to prevent the cart from rolling. All four casters swivel.
- HP 30-Notebook Managed Charging Cart - cart - for 30 notebooks
- Product Type
- Cart
- 124 cm x 63 cm x 107 cm
- 90 kg
- Localisation
- English / United Kingdom
- Recommended Use
- 30 notebooks
- Designed For
- EliteBook 2170p, 2570p, 8470p Notebook, 8470w Mobile Workstation, 8570p Notebook, 8570w Mobile Workstation, 8770w Mobile Workstation; EliteBook Folio 1040 G1; ProBook 4340s, 4440s, 450 G2 Notebook, 4540s, 4545s, 4740s, 6470b, 6475b, 650 G1 Notebook, 6570b
- 124 cm
- 63 cm
- 107 cm
- 90 kg
- Localisation
AV Furniture
- Cart
- Recommended Use
- 30 notebooks
- Cable Management
- Cable Management System (CMS)
- Wheel Diameter
- 10.2 cm
- Retractable doors, Smart Charging technology, removable shelves
- Designed For
- HP EliteBook 2170p, 2570p, 8470p Notebook, 8470w Mobile Workstation, 8570p Notebook, 8570w Mobile Workstation, 8770w Mobile Workstation , HP EliteBook Folio 1040 G1 , HP ProBook 4340s, 4440s, 450 G2 Notebook, 4540s, 4545s, 4740s, 6470b, 6475b, 650 G1 Notebook, 6570b
