The 3 speed Honeywell HT-900 Turbo Force Air Circulator is designed to deliver quiet, powerful personal cooling. The HT-900 is very quiet. The HT-900 adjustable fan head can pivot up to a 90 degree angle and either provide direct cooling or function as an air circulator. Use it on desks counters and table tops or wall-mount the fan to save space. The HT-900 fan helps increase air flow allowing the air conditioning and heating systems to be used at lower settings to help you save money.
- Honeywell HT-900E - cooling fan
- Product Type
- Cooling fan
- Placing / Mounting
- Wall mounted, mobile
- Functions
- Cooling
- Air Flow Control
- 90° oscillating
- Sound Pressure Level (SPL)
- 39 dB
- Black
- 14.5 cm x 26 cm x 28 cm
- 1.35 kg
- 3 years
- Product Type
- Cooling fan
- Form Factor
- Functions
- Cooling
- Air Flow Control
- 90° oscillating
- Black
- Special Features
- Vertical tilt adjustment
Settings, Controls & Indicators
- Fan Speed Settings Qty
- 3
Noise Level Details
- 39 dB
- Power Consumption
- 40 W
- Voltage
- 220 - 240 V / 50 Hz
- 14.5 cm
- 26 cm
- 28 cm
- 1.35 kg
- Warranty
- 3 years
