Hive View Outdoor - HD Security Camera
Quicklinx: DXR3WS00 Mfr#: UK7003793
Hive View Outdoor
Protect your home with our new smart outdoor security camera.
An extra layer of security
An outdoor camera can help keep your home secure and give you more peace of mind from wherever you are. Our weatherproof Hive View Outdoor security camera features night vision, 1080p HD livestreaming, person detection, smartphone notifications, two-way audio and more.
See what's happening day or night
With automatic night vision see what’s happening at any time. Livestream in 1080p HD straight to your smartphone.
Motion, sound and person detection
Hive View Outdoor will automatically start recording if people, motion or sound are detected - and then store that footage securely online for you to see later.
Smartphone notifications
Get a notification when your camera detects sound or motion. It can even send a thumbnail image when a person is detected, so you know if it's a stranger or the kids back from school.
Keep the evidence
Playback footage from the last 24 hours or download recordings to watch later with any Hive View Outdoor purchase. So it's easy to share footage with the police and your insurance company if needed.
Link with your lights
Hive View Outdoor works seamlessly with other Hive products through the Hive app. For example, you can link your Hive Lights so they turn on if there’s motion outside and then it looks like you're home. You don't need a Hive Hub to use your camera, but you'll need one to connect your other Hive devices.
See something? Say something with two-way audio
Speak to whoever's at your door from the Hive app. Tell the delivery driver where to leave your package or an unwelcome visitor to go away, even if you're not at home.
Flexible installation options
With a ladder and some tools, you can set up your Hive View Outdoor camera yourself and start using it right away.
Designed to keep your home secure
Created in collaboration with designer Yves Béhar, Hive View Outdoor fits beautifully onto your home’s exterior walls. And with a 130° wide angle lens and up to 8x digital zoom, it captures a lot of ground, including hidden or vulnerable areas like a patio, back door or balcony.
  • See what's happening day or night
    With automatic night vision see what's happening at any time. Livestream in 1080p HD straight to your smartphone.
  • Motion, sound and person detection
  • Smartphone notifications
  • Link with your lights
    Hive View Outdoor works seamlessly with other Hive products through the Hive app. For example, you can link your Hive Lights so they turn on if there's motion outside and then it looks like you're home. You don't need a Hive Hub to use your camera, but you'll need one to connect your other Hive devices.
  • Flexible installation options
  • Designed to keep your home secure
    Created in collaboration with designer Yves Béhar, Hive View Outdoor fits beautifully onto your home's exterior walls. And with a 130° wide angle lens and up to 8x digital zoom, it captures a lot of ground, including hidden or vulnerable areas like a patio, back door or balcony.
Hive View Outdoor - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, built-in microphone
Camera Mount Type
Surface mount, wall mount
6.6 cm x 6.6 cm x 6.6 cm
210 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Tilting Range (degree)
-45 to +45
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.1
1 - USB power cable - 7.5 m
Voltage
DC 5 V
Motion Detection Technology, Event Notification, Smartphone Monitoring, Audio Detection, video analytics, Person Detection
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Audio Support
Camera Mount Type
Wireless
6.6 cm
6.6 cm
6.6 cm
210 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Max Digital Video Resolution
1920 x 1080
Motion Detection
Digital Zoom
8
Digital Video Capture Resolution
1080p
Lens Construction
Horizontal Field of View (degree)
130
Tilting
Range (degree)
-45 to +45
Network Interface
Screwdriver, wall mount kit, cable clips, magnetic mount, screws, nails, grommets
1 x USB power cable - 7.5 m
AES-128, IP66
Power Requirements
DC 5 V - 2.5 A
Power adapter - external AC 100 - 240 V (50/60 Hz)
Limited warranty - 1 year
-20 °C
45 °C
