Hitachi FX Duo 77" Interactive Whiteboard
Quicklinx: 59H5WS00 Mfr#: EFX77DUOP
The StarBoard FX-Duo-77 offers classrooms the next generation interactive whiteboard by allowing up to two inputs for multi-touch control on a durable, electronic-free surface.
Until now, your interactive whiteboard came with a choice: electronic pen-driven or stylus/finger-driven.
Now you don't have to choose. The Hitachi FX 77 Duo responds to pen or finger. Its low-reflection surface is kind on the eyes. And it caters for multiple users at once.
  • Robust surface
    The surface is robust and the whiteboard works even if there are scratches/dents on the surface.
  • Low reflection
    Projector reflection is minimized making it gentle on the eyes.
  • Input methods
    Use a finger/object or an electronic pen to operate the whiteboard.
  • Simultaneous inputs
    Operate the whiteboard using both hands (gestures).Scroll and zoom-in/zoom-out.
  • Field replaceable digitizer
    A detachable digitizer makes it unnecessary to send the whole unit for repairing.
Hitachi FX-Duo 77" - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
174 cm x 62 cm x 182 cm
41 kg
Movement Detection Technology
Infrared
Accuracy
± 1.5 mm
5-year warranty
174 cm
62 cm
182 cm
41 kg
Input Device
Wired
USB
Infrared
Accuracy
± 1.5 mm
Active Area
118 cm x 157.3 cm
1 x USB 2.0
FCC Class B certified, VCCI
Software Included
Drivers & Utilities
Limited warranty - 5 years
5 °C
35 °C
20 - 80%
