Google Home Mini Kit - includes LB110(E27) and HS100
Quicklinx: GJ8HWS00 Mfr#: 400013648
Bundle includes:
Google Home Mini Smart Speaker (GA00210-UK)
TP-Link LB110 E27 Kasa Smart Wi-Fi LED Bulb with Dimmable Light (includes Bayonet Adapter)
TP-Link HS100 Kasa Smart Wi-Fi Plug
Home Mini
Get hands-free help in any room with Google Home Mini. It's powered by the Google Assistant. You can ask it questions. Tell it to do things. It's your own personal Google. Use your voice to quickly find information about the weather, news, sports and more. Get help with things like your schedule, commute, travel information and more. Control your favorite music, movies and shows, using only your voice. Get personalized responses for everyone at home with voice recognition.
LB110 Smart Bulb
No Hub Required – Connect the bulb to your Wi-Fi at home
Manage Remotely – Easy setup and control from anywhere with the free Kasa app (iOS, Android)
Dimmable Light – Adjust brightness to suit your mood
Voice Control – Pair to Amazon Alexa and the Google Assistant to enable voice control
Monitor Power – Track real-time energy used to stay informed
Save Energy – Reduce energy use up to 80% without brightness or quality loss compared to a 60W incandescent bulb
Compatibility – Compatible with Android, iOS and Amazon Alexa and the Google Assistant
HS100 Smart Plug
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
Grouping – Use Grouping to combine all 3 of your smart plugs on the power strip with other Kasa Smart devices for seamless control with one single tap on your smartphone.
Smart Actions – Enable device interconnections and home automation for your Kasa devices. There are three types of Actions that can be created: "Motion Sensing", "Schedule a Scene" and "Auto-off Timer".
  • A powerful little helper
  • Get answers from Google
  • Manage your day from breakfast to bed
  • Play, pause and rewind, hands-free
  • Control your smart home
    Use your voice to control your compatible lights, thermostats and more.
  • Your voice, your info
Google Home Mini - smart speaker
Smart speaker
Speaker Type
Active
Bluetooth, Wi-Fi
Platform
HomeSeer, Hue, LightwaveRF, Lutron, Nest, SmartThings, ecobee, TP-Link, hive, LIFX, LIGHTIFY
Intelligent Assistant
Google Assistant - direct
Streaming Services
Pandora, Spotify, TuneIn, Google Play Music, iHeartRadio, Chromecast, YouTube MUSIC
Audio Formats
WAV, MP3, FLAC, AAC-LC, LPCM, HE-AAC, Vorbis
Speaker Details
Speaker - mono - active
Chalk
Sound Effects
360° sound
4.2 cm
Dimensions - Diameter
9.8 cm
173 g
Smart speaker
Hands-Free Function
Microphone
Enclosure Colour
Chalk
Enclosure Material
Plastic, fabric, silicone
Speaker System
Speaker Type
Active
Amplifier
Integrated
Sound Effects
360° sound
Bluetooth 4.1, IEEE 802.11a/b/g/n/ac
Internet Streaming Services
Audio Formats
Internet of Things (IoT)
Hub
Integrated
Platform
Google Assistant
Voice Control
Direct
Speaker System Details
Speaker Details
Driver Details
Full-range driver
Connector Type
USB (5 pin Micro-USB Type B)
Power adapter
Supported Host Device OS
Android 4.4 (KitKat) or later, iOS 9.1 or later
Power Source
AC power adapter
Cord Length
1.5 m
Diameter
9.8 cm
4.2 cm
173 g
