TP LINK Tapo P100 Smart Socket
Quicklinx: FMZ6WS00 Mfr#: P100
£8.33 ex VAT
£9.99 inc VAT
Mini Smart Wi-Fi Socket
Remote Control
Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule
Preset a schedule to automatically manage devices
Timer
Create countdown timer lists for connected electronics
Voice Control
Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode
Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design
Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use
No hub required, set up quickly and manage easily through the free app
  • Live smarter by presetting time
    Schedule and Timer features allow you to create weekly schedule and countdown plans. All of your connected electronics will automatically work at your preset time, making your life smart, convenient, and energy-saving.
  • Mighty features and compact size
    Tapo P100 is built small to leave adjacent sockets open, making it convenient for daily use.
  • A deterrent for your home
    Away mode, a feature that intelligently simulates someone being home by turning the plugged in device (like a lamp) on and off, makes it appear that someone is home when you're on long trips to keep away people with ill intent.
  • Share to families
    Not limited to single control, family members can directly share management permissions with each other, saving time and enhancing user-friendliness for the elderly.
Tapo P100 V1.2 - smart plug - 802.11b/g/n, Bluetooth 4.2
Smart plug
Environment
Indoor
Intelligent Assistant
Alexa, Google Assistant
Wireless - 802.11b/g/n, Bluetooth 4.2
Frequency Band
2.4 Ghz
Supported Host Device OS
Android, iOS
5.1 cm x 4 cm x 7.2 cm
Smart plug
Environment
Indoor
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.2
Frequency Band
2.4 Ghz
iOS 9 or later, Android 4.4 (KitKat) or later
Voice control, flame-retardant, up to 2990 Watt, up to 10 A, timer, Away Mode
Internet of Things (IoT)
Aerial
Internal
Product Material
Polycarbonate
Encryption Algorithm
WPA2-PSK, WPA-PSK, WPA, WPA2
Nominal Voltage
AC 220 - 240 V
RoHS
5.1 cm
4 cm
7.2 cm
35 °C
10 - 90% (non-condensing)
Brand: TP LINK
