The Smart Plug extends your Smart Home
The versatile Smart Plug from Bosch Smart Home gives your electrical appliances connected intelligence at lightning speed. Integrate almost any conventional, non-smart electrical appliance into your Bosch Smart Home System with the Smart Plug. Just plug it in: Your coffee machine, radio or standard lamp receive additional, practical functions. You can control the plug as you wish: directly on the appliance, via app or completely automatically via the programming function.
Convenient programming functions
With the programmable timer or with flexible automations your devices switch on and off at your preferred moment: If you fill your filter coffee machine in the evening, it brews coffee in the morning while you are still in the shower.
Better burglary protection for your home
Use lamps or the TV with the Smart Plug to your security solution. The presence simulation service switches integrated devices on and off as if you were at home. The system will effectively deter the attention of intruders.
Lower electricity costs
The app displays the current power consumption of connected devices. If you wish, the Smart Plug can stop the power supply completely - with an automated system, even regularly at set times. Like this, no standby power is consumed.
Compact and efficient
Due to its well thought-out design, you can use the Smart Plug flexibly. It is so compact that you can use several plugs next to each other. What sets it apart from other WLAN or radio plugs is its high performance: You can also switch washing machines or dishwashers on or off via the Smart Plug. It reliably switches electrical appliances with an output of up to 3680 W.
Increases the range
As an intelligent outlet, the wireless plug ensures that conventional household and electrical appliances can communicate with your Smart Home Controller and thus become part of your Smart Home. It also increases the range of your Smart Home Controller for networking with the following devices:
Room Thermostats, Radiator Thermostats, Door/Window Contacts, Smoke Detector, Additional Adapters, Universal Switch (Flex)
Switching on and off with Amazon Alexa and Google Assistant
Thanks to the interaction of the Smart Plug with the voice services Amazon Alexa and Google Assistant, you can now control connected devices even more easily via voice command. Say, for example, "Alexa, turn on the floor lamp" and Alexa transmits the command to the Smart Plug via the Bosch Smart Home Controller.
Integrated enhanced contact protection
The Smart Plug provides more security - for your home and at home: As protection for children, it is not possible to insert objects into only one of the openings. A plastic insert releases the two openings of the wireless plug only by simultaneous pressure. Giving you peace of mind when the children are at play.
Highly visible LED display
The LED indicator on the Smart Plug shows visually whether power is being consumed. You can recognise whether your Smart Home outlet is switched on even from a distance by looking at the LED display which lights up on the top of the Smart Plug.
Due to its well thought-out design, you can use the Smart Plug flexibly. It is so compact that you can use several plugs next to each other. What sets it apart from other WLAN or radio plugs is its high performance: you can also switch washing machines or dishwashers on or off via the Smart Plug. It reliably switches electrical appliances with an output of up to 3680 W. -
Increases the range
As an intelligent outlet, the wireless plug ensures that conventional household and electrical appliances can communicate with your Smart Home Controller and thus become part of your Smart Home. It also increases the range of your Smart Home Controller for networking with the following devices: room thermostats, radiator thermostats, door/window contacts, smoke detector, additional adapters, universal switch (flex). -
Thanks to the interaction of the Smart Plug with the voice services Amazon Alexa and Google Assistant, you can now control connected devices even more easily via voice command. Say, for example, "Alexa, turn on the floor lamp" and Alexa transmits the command to the Smart Plug via the Bosch Smart Home Controller. -
The Smart Plug provides more security - for your home and at home: as protection for children, it is not possible to insert objects into only one of the openings. A plastic insert releases the two openings of the wireless plug only by simultaneous pressure. Giving you peace of mind when the children are at play. -
The LED indicator on the Smart Plug shows visually whether power is being consumed. You can recognize whether your Smart Home outlet is switched on even from a distance by looking at the LED display which lights up on the top of the Smart Plug.
- Bosch Smart Home - smart plug
- Product Type
- Smart plug
- Functions
- Power measuring, turn power on/off
- Power Source
- Power socket
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Connectivity
- Wireless
- Frequency Band
- 869.525 MHz, 863.3 MHz
- Localisation
- United Kingdom
- 7 cm x 3.9 cm x 7.9 cm
- Product Type
- Smart plug
- Functions
- Power Source
- Power socket
- Connectivity Technology
- Wireless
- Frequency Band
- Power scheduling, child protection, smart timer, LED indicator, presence simulation, up to 40000 switching cycles, 2500 V withstand voltage
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- Rated Current
- 16 A
- Power Provided
- 3680 Watt
- IP20
- 7 cm
- 3.9 cm
- 7.9 cm
- 155 g
- Shipping Width
- 9.2 cm
- Shipping Depth
- 10.275 cm
- Shipping Height
- 18.15 cm
- Shipping Weight
- 320 g
- -10 °C
- 35 °C
