Delivers dramatically faster Wi-Fi speeds (up to 867 Mbps) than 802.11n, with more bandwidth per stream 433 Mbps), more capacity for more users (extended channel bonding 80 MHz), broader coverage and better battery life (more data transmit efficiencies reduce power consumption).
The motherboard also includes an exclusive PCIe expansion card that offers support for the Bluetooth 4.0 and IEEE 802.11ac Wi-Fi connectivity. The Bluetooth 4.0 standard includes Smart Ready technology that is debuting on mobile devices including the Apple iPhone. This means that transferring important content from your smart phone or tablet is easier and faster than ever.
More speed better coverage larger capacity 802.11ac, dual band, 80 MHz, 2 x 2
Delivers dramatically faster Wi-Fi speeds (up to 867 Mbps) than 802.11n, with more bandwidth per stream 433 Mbps), more capacity for more users (extended channel bonding 80 MHz), broader coverage and better battery life (more data transmit efficiencies reduce power consumption). -
Support Intel Wireless Display (Intel WiDi)
Intel Wireless Display let you enjoy wireless life at home and at work. Through adapters, you can easily experience your PC on you TV or projectors, Broadcasting Promotion and commercials with more flexibility and efficiency. -
Exclusive Bluetooth 4.0/Wi-Fi expansion card
- Gigabyte GC-WB867D-I (rev. 1.0) - network adapter - PCIe
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Data Link Protocol
- Bluetooth 2.1 EDR, Bluetooth 3.0 HS, Bluetooth 4.0, Wi-Fi 5
- Data Transfer Rate
- 867 Mbps
- PAP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 2.1 EDR, Bluetooth 3.0 HS, Bluetooth 4.0, IEEE 802.11ac
- 867 Mbps
- PAP
- Wi-Fi Multimedia (WMM) support, Ad-Hoc Mode, Wi-Fi Protected Setup (WPS), Smart Ready technology, 802.1x authentication
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Encryption Algorithm
- LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, AES-CCMP
- UL, cUL, CB, IEC 60950-1
- Software Included
- Intel Wireless Display
