Fractal Design Node 804 Computer Case with Side Window
Quicklinx: 9LR8WS00 Mfr#: FD-CA-NODE-804-BL-W
The Node 804 is a micro ATX chassis which focuses on cooling performance and maximum configurability, all packed in an interesting form factor with Scandinavian elegant design.
The dual chamber layout separates hot running components from the cooler ones and allows for unrestricted airflow over the motherboard, processor and graphics card.
The case comes with three excellent 120 mm fans but can be upgraded with several additional fans if needed. The flexibility of this case really gives the users the possibility to create their optimal system build.
Fractal Design Node 804 - tower - micro ATX
System cabinet
Tower
Windowed Side Panel
Brushed aluminium black
I/O Connectors
2 x USB 3.0 , 1 x headphones/speakers , 1 x microphone
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Top panel dust filter, fan speed controller, meshed front panel, front dust filter, floor dust filter, water cooling holes, cable management system, dual chamber layout
No power supply
34.4 cm x 38.9 cm x 30.7 cm
6 kg
Tower
Windowed Side Panel
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
Internal Bays Qty
12
Front Accessible Bays Qty
3
Cooling System
Front: 120 mm fan x 1 / 1000 rpm / hydraulic bearing , Front: 120 mm fan mount x 3 , Rear: 120 mm fan x 1 / 1000 rpm / 1 x 120/140 mm fan supported, hydraulic bearing , Rear: 120 mm fan x 1 / 1000 rpm / hydraulic bearing , Top: 120/140 mm fan mount x 4
CPU Cooler Max Height
160 mm
Video Card Max Length
320 mm
Expansion Bays
8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5" , 2 (total) / 2 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x front accessible - 2.5" , 1 (total) / 0 (free) x front accessible - 5.25" Slim Line
Expansion Slots
5
2 x USB 3.0 , 1 x headphones/speakers - mini-jack , 1 x microphone - mini-jack
No power supply
34.4 cm
38.9 cm
30.7 cm
6 kg
