As the newest member of the Arc family of airflow cases, the Arc Midi R2 is developed with high-performance computer systems in mind. Featuring three high performance silent series R2 fans and ample water cooling options, the Arc Midi R2 layout maximizes airflow throughout the case and keeps even the most demanding systems at cool temperatures. Designed to house even the thickest radiators in both the top and front panels without extensive modifications, the Arc Midi R2 offers all this within a mid size case.
- Fractal Design Arc Midi R2 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x microphone , 1 x headphones
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Rotational drive cage, fan speed controller, meshed front panel, removable front panel, cable management holes, meshed top
- Power Device
- No power supply (ATX)
- 23 cm x 51.5 cm x 46 cm
- 10.7 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 10
- Front Accessible Bays Qty
- 2
- Black
- Cooling System
- Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm , Top: 140 mm fan x 1 / 1000 rpm , Front: 120/140 mm fan mount x 1 , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 8 x Expansion Slot
- 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 23 cm
- 51.5 cm
- 46 cm
- 10.7 kg
