Fractal Design 750W Integra R2 80+ Bronze PSU
Quicklinx: 8FMRWS00 Mfr#: FD-PSU-IN2B-750W
Fractal Design Integra R2 series power supply units (PSUs) provide stable power at an entry-level price. The Integra R2 is a great choice for medium-performance gaming computers and workstations. The visual appearance of Integra R2 series PSUs is proof of Fractal Design's commitment to providing innovative computer components infused with stylish, elegant, contemporary Scandinavian design.
  • 80 PLUS Bronze certified efficiency
    Integra R2 PSUs meet the 80 PLUS Bronze specification for providing power with an efficiency that is typical of PSUS with much higher price points. Additionally, because Integra R2 PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels.
  • Excellent electrical performance
    Fractal Design Integra R2 series PSUs feature excellent DC voltage regulation and ripple suppression: they can deliver their full-rated wattage continuously even with an intake temperature as high as 40 °C.
  • Extremely short 140 mm case
    Integra R2 PSUs are only 140 mm long, which accommodates the smallest ATX-compatible computer cases on the market.
  • Silent, temperature-controlled 120 mm fan
    Generally, larger fans move more air with less noise than smaller fans: Integra R2 series PSUs are equipped with a large, low speed, temperature controlled 120mm fan, which keeps noise level down.
  • Extra-long ATX12 V cable
    Integra R2 PSUs are equipped with a 650 mm long 12 V ("P4") connector cable, which accommodates bottom-mounted-PSU computer cases.
  • Computer protection
    Integra R2 PSUs feature an impressive suit of computer protection, including: over power protection, over voltage protection, short circuit protection, under voltage protection and over current protection.
Fractal Design Integra R2 - power supply - 750 Watt
Power supply - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Bronze
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 24 A , +5V - 20 A , +12V1 - 30 A , +12V2 - 30 A , -12V - 0.3 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties
15 cm x 14 cm x 8.6 cm
3-year warranty
ATX12V 2.31
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
80 PLUS Bronze
Cable ties
Power cable
MTBF
100,000 hours
Cooling System
120 mm fan
Over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, temperature controlled fan
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
Shipping Width
18.7 cm
Shipping Depth
16.5 cm
Shipping Height
15.8 cm
