Fortinet FortiSwitch Rugged 112D-POE Switch
Quicklinx: CJNDWS00 Mfr#: FSR-112D-POE
FortiSwitch Rugged FSR-112D-POE switches deliver all of the performance and security of the trusted FortiSwitch line, but with added reinforcement that makes them ideal for deployments in harsh outdoor environments. Resilient, sturdy and capable of withstanding intense temperature fluctuations, FortiSwitch Rugged ensures the integrity and performance of mission-critical networks in even the extremely challenging deployments.
  • Sturdy construction
    The construction of the FSR-112D-POE is designed to perform while enduring hostile conditions.
  • Redundant power inputs
    Maximizes network availability by eliminating the downtime associated with failure of a power input.
  • Power over Ethernet capability
    Seamless integration of peripheral devices such as cameras, sensors and wireless access points into the network.
Fortinet FortiSwitch Rugged 112D-POE - switch
Switch
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
Jumbo Frame Support
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, TFTP, CLI
Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.1AX
9.64 cm x 10.55 cm x 15.4 cm
1.23 kg
Switch
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
Jumbo Frame Support
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, power, PoE
8 x 1000Base-TX RJ-45 30 W , 4 x Gigabit LAN SFP , 1 x console DB-9
MTBF
30 years
IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, CISPR 22, EN55022 Class B, RoHS, WEEE, IP30
9.64 cm
10.55 cm
15.4 cm
1.23 kg
Limited warranty - lifetime
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
