FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface.
This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect. When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Secure managed switches for wire closet installation
The FortiSwitch 124D-PoE switches are ideal for the next generation applications, where increased productivity can be achieved through faster network access speeds via dedicated Gigabit Ethernet ports. With a compact 1RU form factor, these switches are ideally suited for high density enterprise or classroom wire closet installations, delivering a truly secure network access platform for wired Ethernet devices. -
Simple network deployment and compliance
The Power over Ethernet (PoE) capability enables simple installation of wireless Access Points and IP phones in the network, with power and data being delivered over the same network cable. There is no need to contract electricians to install power for your PoE capable devices anymore, reducing your overall network TCO. By leveraging the FortiSwitch VLAN segmentation feature of the switches, enterprise networks can support the convergence of voice, data and wireless traffic onto a single network platform. FortiSwitch network segmentation can even be managed from the FortiGate interface, simplifying the process of meeting compliance requirements for data separation. -
Single management Framework
Reduces complexity and decreases management cost with network security functions managed through a single console. -
Single policy provisioning
The same security policy can apply to a user or device regardless of how or where they connect to the network. Enables access to certain network ports based on the role of a user within the organization, such as in shared conference rooms or engineering facilities. -
Centralized authentication
All users are authenticated against the same user database, regardless of whether they connect to the wired or wireless network, including temporary guest users. -
Role-based ports
- Fortinet FortiSwitch 124D-POE - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 12 x 10/100/1000 (PoE) + 12 x 10/100/1000 + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 100 W
- Performance
- Switching throughput: 52 Gbps , Throughput: 104 Mpps , Latency: 1 µs
- Capacity
- Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 12
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- Routing Protocol
- IGMPv2, IGMP
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH-2, CLI
- Power over Ethernet (PoE), IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Broadcast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, Link Aggregation Control Protocol (LACP), DHCP client, Management Information Base (MIB), tagged VLAN, Generic VLAN Registration Protocol (GVRP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 46 cm x 33 cm x 4.4 cm
- 8.8 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 100 W
- Performance
- Capacity
- 16K entries
- Routing Protocol
- IGMPv2, IGMP
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
- Status Indicators
- Port transmission speed, power, status, PoE
- 12 x 1000Base-TX RJ-45 PoE , 12 x 1000Base-TX RJ-45 , 2 x Gigabit LAN SFP
- Power Device
- Internal power supply
- Voltage Required
- 19 Watt
- FCC Class A certified, UL, VCCI, C-Tick, cUL, CB, FCC Part 15, RoHS
- 46 cm
- 33 cm
- 4.4 cm
- 8.8 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
