Fairphone Modular Earphones
Quicklinx: FTP5WS00 Mfr#: 000-0024-000000-0003
These modular headphones with dual dynamic drivers deliver a high-quality, balanced sound, while the memory foam earbuds provide increased comfort and noise isolation.
Easily skip tracks, change volume or answers phone calls using the built-in remote and microphone. The 45° angled audio plug provides strain relief to prevent the wires from breaking easily.
Fairphone earphones are modular, so if the cable frays over time, you only need to replace the cable. Using gold plated MMCX connectors, it can be replaced within seconds.
Cable length 1.2M
Compatible with Fairphone 3, as well as most Android and Apple devices with a 3.5mm audio port.
Fairphone Modular Earphones - earphones with mic - 3.5 mm jack
Earphones - wired - 3.5 mm jack
Headphones Form Factor
In-ear
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Controls
Volume, answer/end, skip track
Fairphone 3, 3+
Audio Output
In-ear
Dynamic
Wired
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
Built-in
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Cable
Cable Length
1.2 m
Plated Connector
Gold
Cable Details
Headphones cable - detachable - 45° angled - 1.2 m
Fairphone 3, 3+
