EZVIZ C6CN Pan/Tilt Smart Indoor Camera
Quicklinx: FXFYWS00 Mfr#: CS-CV246-A0-1C2WFR
  • microSDHC Card
  • microSD Card
Introducing the EZVIZ Pan and Tilt camera Imagine that you are at work and an intruder has come into your home – your Pan/Tilt Wi-Fi Smart Camera will alert you straight away with a message via the EZVIZ app to your smartphone, take a snapshot and even proceed to record the events and the suspicious activity. What’s more, the camera will track and follow them too, gathering up as much footage as possible.
Baby/Elderly/Pet Monitor Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Pan/Tilt & Motion Tracking With the 340-degree Horizontal, 105-degree vertical rotation Pan & Tilt feature, you can see everything in the room, keeping a lookout of the whole room. If it notices something moving (like the dog with something in its mouth), the camera will track the movement automatically across the room, providing the best footage possible. This can also be manually moved around via your EZVIZ smartphone app.
Be Informed Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night The Infrared (IR) allows clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
What’s in the box 1x EZVIZ HD 1080p Pan Tilt Camera 1x Power Adapter with 3m Cable (3.5mm jack connection) 1x Mounting Accessories and set of screws 1x Quick Start Guide
  • Zero blind spots
    Keep tabs on every corner with just one C6CN. Its expansive 360-degree field-of-view ensures full coverage, so you don't miss a thing.
  • Smart and neat
    When it detects a moving object, the C6CN is smart enough to automatically track its motion while alerting you with an image in real time.
  • Protect your privacy
    Want a bit more privacy? The thoughtfully designed privacy shutter allows you to turn the lens off - whenever, wherever.
  • Simple installation
    Install the C6CN the way suits your home. Use the image flipping feature, and feel free to place it on a shelf or fix it to your wall or ceiling.
  • Always connected
    Connect the C6CN to your home network, either wired or wirelessly. Enjoy a stable connection without dropping out.
EZVIZ C6CN - network surveillance camera
Network surveillance camera - pan / tilt - indoor
Audio
Yes: two-way audio capability
8.77 cm x 8.77 cm x 11.27 cm
260 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
22 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/2.9"
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Lens Iris
F/2.2
Panning Range (degree)
340
Tilting Range (degree)
120
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - USB cable - external
Voltage
DC 5 V
Privacy shutter, smart tracking, cloud recording, progressive scanning, self-adaptive shutter, infrared cut filter, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), motion detection, anti-flicker, dual video stream, heartbeat, image mirror, password protection, watermark, 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK
1-year warranty
Environmental Parameters (operating)
-10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wired, wireless
8.77 cm
8.77 cm
11.27 cm
260 g
Camera
Colour - Day&Night - pan / tilt - indoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
PS CMOS 1/2.9"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Lens Iris
F/2.2
Horizontal Field of View (degree)
82
Diagonal Field of View (degree)
94
Panning
Range (degree)
340
Tilting
Range (degree)
120
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Camera mount base, drill hole template, screw kit
1 x USB cable - external
CE/EMC, FCC-ID, KCC, R&TTE, REACH, RoHS, UL, WEEE
Power Requirements
DC 5 V - 1 A
Power adapter - external 5 Watt
Limited warranty - 1 year
Shipping Width
10.3 cm
Shipping Depth
10.3 cm
Shipping Height
18.8 cm
-10 °C
45 °C
Relative Humidity (operating)
