Ring Indoor Camera (2nd gen) - White 2-Pack
Quicklinx: H8ZJWS00 Mfr#: B0BGT4K2NW
Type: Indoor Camera
Compatible With: Alexa
43 In Stock
£66.66 ex VAT
£79.99 inc VAT
Get the whole picture about what's happening inside your home, or keep the picture private by using the manual, removable Privacy Cover to turn off audio and video with a simple swivel. Versatile protection and personalised peace of mind - that’s Indoor Camera (2nd Gen). The ideal way to check in on your home from wherever you are, Indoor Camera (2nd Gen) is a versatile plug-in Security Camera, designed to go almost anywhere indoors.
Easy to install and with a compact design, Indoor Camera (2nd Gen) simply plugs in to a standard electrical socket, so you can add protection wherever you need it inside your home.
Manufacturer Warranty - 1 Year
  • Peace of mind, home or away
    Wherever you are, with 1080p HD video, Advanced Pre-Roll and Color Night Vision you can see more of what's happening at home, even after dark. Speak to whoever is on camera in real-time with Two-Way Talk or keep it all private with the manual privacy cover that turns off your Indoor Camera (2nd Gen) until you need it next.
  • Privacy and security at your fingertips
    Feel safe, knowing your home's protected. Indoor Camera (2nd Gen) includes features to keep things private and put you in control of when the camera is active, what it sees, what it hears and a whole lot more.
  • Manual privacy cover
    Turn off the camera and mic with the manual privacy cover. Swivel it to the side to reactivate. Or remove it entirely for total protection at all hours.
  • Privacy zones
    Control what your Indoor Camera (2nd Gen) sees or records by blacking out off-limits areas, such as the bathroom door or your work desk.
  • Privacy settings
    Customize who can see your videos with end-to-end encryption. Control the behavior of all your Ring devices. And add extra layers of security to your account. All your privacy settings, all in the Ring app.
  • Advanced motion detection and alerts
    Get real-time alerts whenever motion is detected, customize your Motion Zones to set where you want to detect motion and capture motion a few seconds early to help piece together what's happening with Advanced Pre-Roll.
  • Place it, mount it, move it, love it
    Talk to your pet in their favorite spot or keep an eye on your garage any time of the day. Designed for easy installation and with a flexible swivel mount, Indoor Camera (2nd Gen) can go almost anywhere - even up high on a wall or ceiling beam. Plus, it's plug-in, making it oh-so-easy to move where you need it.
  • Build a smarter home
    Connect your Ring Security Cameras to compatible devices and Alexa to start protecting your whole home.
Ring Indoor Cam (2nd Gen) - network surveillance camera
Network surveillance camera
Wireless
Camera
Colour - Day&Night
Motion Detection
Wireless
Camera
Colour - Day&Night
Motion Detection
Type: Indoor Camera
Brand: Ring
