Ezviz BC1 Battery Camera Add-on (Only works with the base station)
Quicklinx: H0W4WS00 Mfr#: CS-BC1-A0-2C2WPBL
  • microSDHC Card
  • microSD Card
Add-on camera for expanded protection.
Used together with a base station, the BC1 wire-free camera delivers well-rounded home protection for up to a full year on one single charge. The BC1 inherits EZVIZ’s core technologies of color night vision, two-way talk, active defense, and more, showcasing unparalleled usability in any household.
  • Year-long protection on a single charge
    Equipped with an impressive rechargeable battery, the BC1 can last for up to a year on one full battery charge.
  • Vivid night vision
    Thanks to two built-in spotlights, the BC1 can render vivid color imaging even in pitch-black darkness. This allows you to see crucial details that would otherwise be lost.
  • Motion alerts are more accurate
    Integrating a PIR sensor and the person-shape detection algorithm, the BC1 camera is intelligent enough to distinguish persons from other moving objects, keeping you safe while also reducing unwanted notifications.
  • A vigilant guard over your property
    Users can set specific time frames for detection. Once the camera detects a person-shape, the BC1 will automatically set off a siren and flash two spotlights to let them know they have been detected.
  • Customizable voice messages
    A thoughtful product by design, the BC1 allows you to create unique voice messages for greeting or deterrence.
  • Fast and easy wire-free setup
    Featuring a large battery, Wi-Fi connectivity, and a magnetic base, the BC1 camera requires exactly zero professional help in installation. Simply attach the camera to any metallic surface and it is good to go!
  • Built to last
    The BC1 camera features an IP66 enclosure, offering high levels of protection against dust and water and delivering long-lasting protection in even tougher weather conditions.
  • Helps you save money on storage and bandwidth
    The BC1 camera features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space required by the previous H.264 video compression standard.
EZVIZ BC1 - network surveillance camera
Network surveillance camera - fixed - dustproof / waterproof
Audio
Yes: two-way audio capability, built-in omni-directional microphone, built-in speaker
6.28 cm x 10.476 cm x 6.28 cm
1.304 kg
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - USB cable
Voltage
DC 5 V
3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), PIR-based motion detector, Active Defense, Voice Alert, Colour Night Vision
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless
6.28 cm
10.476 cm
6.28 cm
1.304 kg
Camera
Colour - Day&Night - fixed - dustproof / waterproof
Digital Video Format
H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
10 m
Video Capture
1920 x 1080, 50 Hz @ 25 fps , 1920 x 1080, 60 Hz @ 30 fps
Image Sensor
2 MP CMOS 1/2.8"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Horizontal Field of View (degree)
108
Diagonal Field of View (degree)
128
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Magnetic base, screw base, mounting bracket, drill hole template, screw kit
1 x USB cable
IP66, FCC, WEEE, RoHS, REACH, UL
Power Requirements
DC 5 V
Power adapter 5 Watt
Lithium Ion 12900 mAh (up to 365 days)
Software Included
Linux
Limited warranty - 1 year
Shipping Width
26 cm
Shipping Depth
21.7 cm
Shipping Height
18 cm
-20 °C
45 °C
Relative Humidity (operating)
