The unbeatable performance of the EVGA SuperNOVA G2 power supply line is now available in a 650 watt version. Based on the award winning G2 power supplies, these units feature 80 Plus Gold rated efficiency, and clean, continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low to medium load operations. Backed by an award winning 7 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 650 G2 power supplies offer unbeatable performance at an unbeatable value.
80 PLUS Gold certified, with 90% (115VAC) / 92% (220VAC~240VAC) efficiency or higher under typical loads
Highest quality Japanese brand capacitors ensure long-term reliability
Fully Modular to reduce clutter and improve airflow
NVIDIA SLI & AMD Crossfire Ready
Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
Ultra Quiet Fan with ECO Intelligent Thermal Control Fan system (Zero Fan Noise < 45°C)
Unbeatable 7 Year Warranty and unparalleled EVGA Customer Support.
- EVGA SuperNOVA 650 G2 - power supply - 650 Watt
- Power supply - internal
- 80 PLUS Certification
- 80 PLUS Gold
- 2.7 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output connectors
- 1 x power 24 pin ATX , 2 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 6 pin PCI Express power
- Cooling System
- 140 mm fan
- 15 cm x 16.5 cm x 8.5 cm
- 7 years warranty
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 24 A , +5V - 22 A , +12V - 54.1 A , +5VSB - 3 A , -12V - 0.8 A
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- Modular Cable Management
- 80 PLUS Gold
- Cables Included
- Power cable - external - 1.5 m , 3 x Serial ATA cable - external - 70 cm , 2 x PCI Express power cable - external - 85 cm , Power 24 pin ATX modular cable - external - 60 cm , Power 8 pin EPS12V modular cable - external - 85 cm , Floppy adapter - external - 10 cm
- MTBF
- 100,000 hour(s)
- Cooling System
- 140 mm fan
- Solid capacitors, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, Eco-Mode, fully modular
- TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
- Limited warranty - 7 years
- 0 °C
- 50 °C
- 15 cm
- 16.5 cm
- 8.5 cm
- 2.7 kg
