The EB-4850WU boasts high definition picture quality and a 5,000:1 contrast ratio. This ensures your important presentations are projected in the best possible way.
Thanks to a variety of user-friendly installation features, this projector is easy to set up and use. Its x1.8 wide zoom ratio, as well as manual vertical keystone correction, and arc and point correction, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input and Display Port, you can connect a variety of high definition devices to play your content effortlessly. In addition, the lamp and filter are easily replaceable which help keep maintenance straightforward, ensuring your projections are as bright and clear as possible.
While presenting, the side-by-side split screen function lets you present from two different sources, such as a separate laptop, for much more in-depth and impressive presentations.
- Epson EB-4850WU - 3LCD projector
- 3LCD projector - High Definition 1080p
- Built-in Devices
- Speaker
- Brightness (White)
- 4000 lumens
- Brightness (Colour)
- 4000 lumens
- Contrast Ratio
- 5000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 4000 hours / up to 6000 hours (economic mode)
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 368 Watt
- 47.2 cm x 35.4 cm x 15.9 cm
- 6.6 kg
- 2 years warranty
- 3LCD projector - HD 1080p
- Built-in Devices
- Speaker
Projector
- 4000 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.4 m - 15 m
- Throw Ratio
- 1.26 - 2.3:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Bulb type
- 260 Watt
- Bulb life cycle
- sRGB colour profile, EPSON 3LCD technology, 16:10 aspect ratio support
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.65-2.55
- Zoom Factor
- 1.8x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 50% / 50%
- Horizontal Lens Shift
- 10% / 10%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, S-Video
Speakers
- Integrated
- Output Power / Channel
- 10 Watt
- 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC , 1 x S-video input , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Nominal Voltage
- 368 Watt
- Power Consumption Stand by
- 0.39 Watt
- Software Included
- Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 47.2 cm
- 35.4 cm
- 15.9 cm
- 6.6 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 20 - 80%
- Sound Emission
- 38 dBA
- Sound Emission (Economic Mode)
- 32 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £5.79 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £15.65 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £30.41 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £41.19 |
C2G Pro HDMI to VGA Converter | In Stock | £46.73 |
