Make your home smarter with Mi, Home! Alexa Controlled Smart Plugs
The Energenie Mi, Home Starter Pack contains a remote control, x3 control adapters and gateway. The Mi, Home adapters can be controlled via the Mi, Home app or web browser using the Mi, Home Gateway. This product receives commands from the Mi, Home gateway and doesn't send a confirmation of action back to it. The adapters can also be used with our other features such as timers. As well as timers, the Sockets can be controlled with IFTTT (If This Then That), this allows you to turn them on using the weather, ESPN, facebook to name but a few. It also means they can be used in conjunction with the Phillips Hue and Nest, for example.
The technical Info...
- Input voltage: 5VDC
- Input current: 150mA
- Power connection: MicroUSB (Power only)
- Ethernet connection: RJ45, cat5e patch cable
- Radio Frequency: 433MHz Band
- Certified by Amazon to work with Alexa (Echo, Dot, kindle, Fire)
- Energenie Mi|Home Starter Pack - home automation kit
- Product Type
- Home automation kit
- Functions
- Energy use monitor, power measuring
- Power Source
- Power adapter
- Internet of Things (IoT) Platform
- Hue
- Package Content
- Remote control, smart plug, gateway
- Connectivity
- Wireless
- Frequency Band
- 433 MHz
- 1-year warranty
- 16 cm x 5 cm x 10 cm
- Product Type
- Functions
- Power Source
- Power adapter
- Package Content
- Components
- 3 x smart plug , Gateway , Remote control
- Connectivity Technology
- Wireless
- Frequency Band
- 433 MHz
- Platform
- Hue
- Compatible Services
- IFTTT
- Included Accessories
- Power adapter, network cable, USB cable
- Warranty
- 1-year warranty
- 16 cm
- 5 cm
- 10 cm
- 750 g
