Inconspicuous, compact design
This small, unassuming accessory allows you to turn any light – even one in which you can’t place a Hue bulb – into a smart light so that you can control it via the Hue app or voice. Use Bluetooth for instant light control or connect to the Hue Bridge to unlock more features.
- Bluetooth enabled
- Hue Bridge enabled
- Add any light to your Hue system
- Instant control via Bluetooth
- Control with app or voice*
- Add Hue Bridge to unlock more
The Philips Hue Smart plug was designed to blend into any environment. -
Create a more versatile home
Small, white and with a subtle design, the Smart plug allows you to add any light to your Hue system without any added wires or hassle. -
- Philips Hue - smart plug - Bluetooth, ZigBee Light Link - white
- Product Type
- Smart plug
- Power Source
- Power socket
- Intelligent Assistant
- Google Assistant, Alexa
- Connectivity
- Wireless - Bluetooth, ZigBee Light Link
- Frequency Band
- 2.4 - 2.4835 GHz
- White
- 2-year warranty
- 6 cm x 6 cm x 6.4 cm
- Product Type
- Smart plug
- Power Source
- Power socket
- Connectivity Technology
- Frequency Band
- 2.4 - 2.4835 GHz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- White
- Warranty
- 2-year warranty
- IP20
- 6 cm
- 6 cm
- 6.4 cm
- 113 g
- Shipping Width
- 7.2 cm
- Shipping Depth
- 7.2 cm
- Shipping Height
- 14 cm
- Shipping Weight
- 173 g
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
