EE 4GEE Wifi 2 (2018)
Quicklinx: F5K5WS00 Mfr#: EE120
Keep yourself connected
The 4GEE WiFi router is the ideal way to keep connected with all your devices. Connect up to 20 devices at any one time to make the most of your tech. You can create your own secure 4G WiFi network wherever you are – never rely on open networks again.
Stay online for longer
With up to 15 hours of uncharged use, 4GEE WiFi will keep you online for even longer. Keep all your tech connected with devices and a network you can rely on. 4GEE WiFi router boasts a USB Type-C port, so it can also work as a power bank to charge your phone.
Compact and portable
The 4GEE WiFi router has been redesigned in a super-compact, rectangular, lighter size and can be easily transported with you – ideal for those with an on-the-go lifestyle. Keep all your devices connected on EE, the UK network with 4G in more places than any other.
Super Speedy
The all new and improved 4GEE WiFi will have you up and running with access to our fastest UK 4G speeds.
