Edimax AC1750 Long Range Dual Band Access Point
Quicklinx: BYRBWS00 Mfr#: WAP1750
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11g, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11n + 1 more
Compatibility: PC
  • IEEE 802.11n
£163.36 ex VAT
£196.03 inc VAT
Premium Solution with Super-High Speed AC1750 for Elite Performance
The WAP1750 is a premium wireless solution designed for SMBs which demand elite network performance. The product features the latest 3 x 3 IEEE 802.11ac technology for concurrentdual-band wireless speeds up to 1750Mbps. A wall-mounted design and industrial-grade build quality combined with user-friendly operation and an extensive feature set, make an ideal high-performance dual-band solution for demanding day-to-day enterprise operations.
For businesses that demand security, flexibility and speed – the Edimax Pro series has a wide range of potential applications from office environments to schools, campuses, hotels and hospitals. Multiple SSIDs can be configured for different departments or user groups and a built-in RADIUS server provides additional verification with a scalable AP array architecture for central management of multiple access points. High-density capacity for up to 100 simultaneous clients ideal for BYOD workplaces or other environments with a high volume of clients and wireless devices, and fast roaming allows for seamless transitions between multiple access points. Power over Ethernet support (PoE) and an intuitive web-based management interface provide deployment flexibility and extensive management options for company MIS departments and network administrators. An optional security cover also prevents physical theft or tampering, along with a rogue AP detection function to safeguard your network from unauthorized access.
When performance and security are critical for your business, you need products that are engineered for your industry. The Edimax Pro series is designed to help your business and provide the connectivity that you rely on every day, with safety and effectiveness guaranteed, and the WAP1750 offers the highest level of wireless performance on the market today.
  • High performance design with high-speed dual-band 11ac
    State-of-the-art IEEE 802.11ac wireless technology delivers the Giga-fast Wi-Fi speeds that today's fast-moving modern business environments demand. And simultaneous dual-band coverage means maximum flexibility for mobile-centric business productivity applications. High speeds can handle even the bandwidth intensive tasks, perfect for audio, video and voice applications and significantly faster than traditional 802.11n Wi-Fi. Additionally Edimax Pro series products feature other high-performance design features such as solid capacitors for significantly longer lifespans than traditional non-solid alternatives, generating less heat and delivering increased stability. Durable, robust and ready for business environments.
  • Wide coverage & multiple SSIDs
    With adjustable RF output power and high receiver sensitivity, Edimax Pro access points are equipped to provide wide coverage where it's needed. Suitable for large spaces across office floors, shop floors, hospital wards, or conference rooms, get the wireless coverage that staff and systems need to operate efficiently. Keep every corner of your business connected and differentiate user groups, departments or guests with separate SSIDs with independent security. Wide, accessible Wi-Fi coverage with strong security protects sensitive company information and supervise access to internal networks.
  • Seamless mobility
    Typical wireless access points can effectively cover a large radius under normal usage. Wireless devices can stay seamlessly connected in environments where connectivity may be a critical component of efficiency and productivity, and benefit from mobility with high-speed connectivity across a range of wireless devices: smartphones, tablets and computers, throughout an entire organization.
  • Hotels, offices, schools and hospitals
    Edimax Pro series access points, with high-speed 11ac high-density networking for many simultaneous users, are ideal for multi-tenant unit buildings, hotels, resorts, hospitals, campuses, conventions or anywhere with large-scale network use, with safety and effectiveness guaranteed.
Edimax Pro WAP 1750 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
18.3 cm x 18.3 cm x 3.6 cm
560 g
Radio access point
18.3 cm
18.3 cm
3.6 cm
560 g
External
Wireless
Data Transfer Rate
1750 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, diagnostic
Power over Ethernet (PoE), VPN support, VLAN support, manageable, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, wall mountable, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), RADIUS support, roaming function, Wi-Fi Protected Setup (WPS), Multiple SSID support, hidden SSID, reset button, Management Information Base (MIB), DiffServ Code Point (DSCP) support
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
3
Gain Level
2 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45
FCC, RoHS
PoE
15 Watt
50 °C
0 - 90%
Speed: 1750Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Edimax
