Edimax AC1200 Long Range Dual Band Access Point
Quicklinx: BYR9WS00 Mfr#: WAP1200
  • IEEE 802.11n
2 x 2 AC Dual-Band Wall-Mount PoE Access Point
Powerful 2.4GHz & 5GHz Dual-Band SMB Solution
  • 802.11AC Dual-Band High Speed
  • Easy Installation
  • Designed for High Density Usage
  • Multiple SSIDs for Security Management
  • Fast Roaming
  • Wide Coverage & High Sensitivity
  • Seamless Mobility
  • Power over Ethernet
  • Built-In RADIUS Server
  • Business Environments
  • Central Management
  • Optional Security Cover
The WAP1200 is high-speed, robust wireless solution designed to meet the needs of modern SMBs with the latest IEEE 802.11ac technology for wireless speeds up to 1200Mbps. A wall-mounted design, industrial-grade performance and build quality combined with user-friendly operation, 11ac speeds and an extensive feature set make an ideal dual-band solution for day-to-day enterprise operations.
For businesses that demand security, flexibility and speed – the Edimax Pro series has a wide range of potential applications from office environments to schools, campuses, hotels and hospitals. Multiple SSIDs can be configured for different departments or user groups and a built-in RADIUS server provides additional verification with a scalable AP array architecture for central management of multiple access points. High-density capacity for up to 100 simultaneous users is ideal for BYOD workplaces or other environments with a high volume of users and wireless devices, and fast roaming allows for seamless transitions between multiple access points. Power over Ethernet support (PoE) and an intuitive web-based management interface provide deployment flexibility and extensive management options for company MIS departments and network administrators. An optional security cover also prevents physical theft or tampering, along with a rogue AP detection function to safeguard your network from unauthorized access.
When performance and security are critical for your business, you need products that are engineered for your industry. The Edimax Pro series is designed to help your business and provide the connectivity that you rely on every day, with safety and effectiveness guaranteed.
  • High-performance design with high-speed 1200 Mbps dual-band 11ac
    Excellent IEEE 802.11ac wireless technology delivers the Giga-fast Wi-Fi speeds that today's fast-moving modern business environments demand. And simultaneous 2.4 GHz & 5 GHz dual-band coverage means maximum flexibility for mobile-centric business productivity applications. Speeds up to 300 Mbps on the 2.4 GHz band and 867 Mbps on the 5 GHz band can handle even the most bandwidth intensive tasks, perfect for audio, video and voice applications and significantly faster than traditional 802.11n Wi-Fi.
  • Wide coverage & multiple SSIDs
    With adjustable RF output power and high receiver sensitivity, Edimax Pro access points are equipped to provide wide coverage where it's needed the most. Suitable for large spaces across office floors, shop floors, hospital wards, or conference rooms, get the wireless coverage that staff and systems need to operate efficiently. Keep every corner of your business connected and differentiate user groups, departments or guests with up to 32 separate SSIDs with independent security. Wide, accessible Wi-Fi coverage with strong security to protect sensitive company information and supervise access to internal networks.
  • BYOD solutions & high density networking
    Bring Your Own Device (BYOD) is becoming an increasingly commonplace company trend in offices and enterprise environments worldwide. Employees are using their own smartphones, tablets and laptops with the cloud-connected productivity apps to get things done, and traditional 2.4 GHz is crowded, so most of these devices need or support high-speed 5 GHz Wi-Fi. And in offices, hotels, schools or other densely populated environments, access points need to cope with a high volume of users connecting to the network at any time, whether it's customers or employees. Edimax Pro solutions support the 802.11ac 2.4 GHz & 5 GHz dual-band Wi-Fi along with high-density capacity to support up to a hundred users simultaneously, ideal for BYOD workplaces and a large number of wireless devices.
  • Hotels, offices, schools and hospitals
    Edimax Pro series access points, with high-speed 11ac high-density networking for up to 100 simultaneous users, are ideal for multi-tenant unit buildings, hotels, resorts, hospitals, campuses, conventions or anywhere with large-scale network use, with safety and effectiveness guaranteed.
  • Rogue AP detection & wireless isolation
    Rogue access point detection can identify any unauthorized SSIDs which may have been installed in an otherwise secure network with malicious intent, and L2 wireless isolation provides wireless security.
Edimax Pro WAP 1200 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Concurrent users per radio: 50
Power Over Ethernet (PoE) Supported
PoE+
18.3 cm x 18.3 cm x 3.6 cm
527 g
Radio access point
18.3 cm
18.3 cm
3.6 cm
527 g
External
Wireless
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
L2TP, IPSec, PPTP
Remote Management Protocol
HTTP, CLI, HTTPS, SNMP 1, SNMP 2c, SNMP 3, SSH, Telnet
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, diagnostic
Wall mountable, power over Ethernet (PoE), manageable, Multiple SSID support, RADIUS support, roaming function, hidden SSID, MAC address filtering, Wireless Distribution System (WDS) support, Quality of Service (QoS), IPv6 support, VPN support, Wi-Fi Protected Setup (WPS), reset button, VLAN support, Rapid Spanning Tree Protocol (RSTP) support, DiffServ Code Point (DSCP) support, Management Information Base (MIB)
Encryption Algorithm
WEP, WPA, WPA2
Authentication Method
Extensible Authentication Protocol (EAP), RADIUS
IEEE 802.3az, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11e, IEEE 802.3af, IEEE 802.3at, IEEE 802.1x, IEEE 802.1Q, IEEE 802.1p
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
2 dBi
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45
FCC, RoHS
PoE+
12 watt
50 °C
0 - 90%
