Flexible, resistant and strong: the sleeves from the FLOW family have been designed to fit your notebook perfectly - like a second skin. Your device will be kept safe during your commute to the office or university. The outside of the sleeve is made from durable, elastic neoprene.
- DICOTA Skin FLOW - notebook sleeve
- Product Type
- Notebook sleeve
- Blue, anthracite
- Product Material
- Neoprene
- 36 cm x 2 cm x 27 cm
- 240 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 13" - 14.1" / 33 cm - 35.8 cm
- Limited lifetime warranty (Germany - 30 years)
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 36 cm
- 2 cm
- 27 cm
- 240 g
- 14.1"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 2.5 cm
- Closure Type
- Zipper
- Lining Material
- Soft nylex
- Blue, anthracite
- Limited warranty: - lifetime , Limited warranty: Germany - 30 years
