Dicota Wireless Mouse SILENT V2
Quicklinx: HG2XWS00 Mfr#: D32003
More than 50 In Stock
£6.72 ex VAT
£8.06 inc VAT
This slim, elegant mouse with optical sensor is an excellent and high-quality input and pointing device for the office or on the road. It has a rubberized scroll wheel that allows noiseless scrolling and clicking.
Precise navigation thanks to three-level mouse sensitivity of 800/1200/1600 dpi. By changing the dpi, you can instantly adjust the pointer speed to suit the type of work you are engaged in. There is no need to install any additional software as the mouse works with USB Plug-and-Play. The integrated and pre-paired nano receiver simply has to be plugged into the notebook or computer and the mouse is ready to start within a few seconds. Suitable for right- and left-handed. The mouse runs on one AA battery.
DICOTA Silent - v2 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6.3 cm x 11.5 cm x 3.3 cm
60 g
Wireless Receiver
Nano USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 dpi
Quiet clicking sound, rubberised scroll wheel
AA type
Mouse
Wireless Receiver
Orientation
6.3 cm
11.5 cm
3.3 cm
60 g
Product Material
Plastic
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
Performance
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Brand: Dicota
