Dicota Eco Backpack Plus BASE 13-15.6"
Quicklinx: G921WS00 Mfr#: D31839-RPET
19 In Stock
£30.72 ex VAT
£36.86 inc VAT
The compact Plus BASE backpack offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case fully protects your device and the elastic strap also secures it within its compartment. The spacious main section is divided so that documents and accessories can be stored separately. The front pocket has practical smaller compartments so you can organize smaller items like your smartphone, pens or chargers. You can safely store your passport, wallet or other valuables in the hidden zipped compartment on the back of the case. There is space for your water bottle or umbrella in the easily accessible mesh side pockets.
You can therefore ensure that everything you need is always to hand. The backpack's ergonomic padding makes it comfortable to wear on your back and the shoulder straps can also be adjusted for further comfort. The Eco Backpack Plus BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
DICOTA Eco Plus BASE - notebook carrying backpack
Notebook carrying backpack
Product Material
300D RPET polyester
31 cm x 19 cm x 45 cm
850 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
High-Density Foam (HDF), elastic fixation straps, padded notebook compartment
Carrying Strap
Adjustable padded shoulder straps, padded carry handle
30 years warranty
Product Material
300D RPET polyester
31 cm
19 cm
45 cm
850 g
15.6"
Additional Compartments
Mobile phone, cable, passport, documents, pens, wallet, chargers, power bank, front zippered pocket, back zippered pocket, 2 x side mesh pocket
Carrying Strap
Closure Type
Zipper
24 litres
REACH
Limited warranty: - 30 years
Brand: Dicota
