Dicota DataDesk for HP 100 Printer
Quicklinx: 875RWS00 Mfr#: D30408
The professional, transportable and lockable office for working on the move with a notebook and printer. This device is attached in the hard shell of the case. The printer is embedded in the bottom of the case in a shape intended for it. The mobile computer accessories are perfectly protected by the aluminum frame design; the side walls of the case are made from light and long-lasting 'Conpearl' plastic.
The interior of the attache case, which contains the mobile hardware, is made from thermoformed ABS. The notebook is fixed via dual lock attachments and support brackets made from plastic for notebook sizes of up to 365 x 315 x 45 mm. The printer fits perfectly into the ABS shape in the bottom of the case it was intended for, thus the notebook and printer remain wired into the case when in use. Paper guide is space-saving and crease-resistant beneath the notebook platform. The electricity supply of the notebook and printer takes place via a 220 V low heat device connector on the case outer shell. The detachable case lid offers generous space for storing mobile accessories; one of the pockets can be locked with a combination lock.
DICOTA DataDesk - printer and notebook carrying case
Printer and notebook carrying case
Package Content
Adhesive non-slip pads, power cable, USB cable, 2 x keys
Product Material
Aluminium, ABS plastic, conpearl
60 cm x 15 cm x 47 cm
5.3 kg
Notebook Compatibility
15.4"
Safety lock, lockable catches, 220V power socket, hard shell key lock
Carrying Strap
Hand grip
HP 100
Product Material
Package Content
60 cm
15 cm
47 cm
5.3 kg
15.4"
Notebook Compatibility Dimensions
36.5 cm x 31.5 cm x 4.5 cm
Additional Compartments
Power adapter, documents, personal accessories, mobile accessories
Carrying Strap
Hand grip
Interface Provided
Connector Provided
RJ-45 x 1
Key lock
Limited warranty: - 2 years
HP 100
