Dicota Eco Multi Plus SELECT 14-15.6"
Quicklinx: FC2ZWS00 Mfr#: D31640
£45.12 ex VAT
£54.14 inc VAT
Made from high-quality recycled PET, the SELECT collection cares for the planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi Plus SELECT's main material is made of 8 recycled PET bottles. The bag offers perfect protection for your devices and is comfortable and easy to carry. There's also space for a tablet and accessories in this spacious bag, which offers clever storage solutions.
The lockable, clamshell-style main compartment keeps your 14 - 15.6" notebook protected with surrounding high-density foam (HDF) padding and soft Nylex, a metal-reinforced frame, and reliable fastening thanks to the fastening strap. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional zip compartment on the lower front of the bag provides space for a charger and cable. The comfortably molded riveted carrying handle, a length-adjustable and padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport.
DICOTA Eco Multi Plus SELECT - notebook carrying case
Notebook carrying case
Product Material
PET, high-density foam, soft nylex
42 cm x 12.5 cm x 30 cm
1 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Carrying Strap
Shoulder carrying strap, trolley strap, top carry handle
Product Material
42 cm
12.5 cm
30 cm
1 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Mobile phone, pens, tablet, front pocket, charger
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Brand: Dicota
