Dell S2825CDN Colour Laser Multifunction Printer
Quicklinx: BTWWWS00 Mfr#: 210-AFRM
Empower your teams to collaborate efficiently on a color smart multifunction printer with low cost-per-page printing.
  • Simplify collaboration
    Handle large-volume scans easily and with less waiting time using the single-pass, dual head duplex automatic document feeder. Print from and scan from the printer for improved collaboration. When paper is detected in the ADF or scan bed, the recent screen is automatically displayed with up 8 previous ADF or scan related tasks, saving you time and effort.
  • Efficient performance
    Print in vibrant color and fax, scan and copy on one device. Get fast print speeds and a high duty cycle. Enjoy low cost-per-page printing and save paper with automatic two-sided printing. This printer also supports printing on recycled, renewable content and chlorine-free paper. Just tap the icons on the on-screen dock menu or swipe the 4.3" touchscreen for easy activation. Launch recent tasks, including associated settings, with one touch of the recent icon. Printing large, complex files is hassle-free with a built-in memory. And enjoy convenient features such as Private/Public Mail Box Print and Proof Print.
  • Easy maintenance
    Reduce energy consumption and toner cartridge size with improved low-melt toner technology. Amazing toner cartridge design prevents spillage during shipping, eliminating the need for sealing tape, so replacement is quick and hassle-free upon delivery. Paper jams are easy to access and address without tearing so you can get back to work quickly.
  • Essential security
    Keep sensitive documents private with the Secure Print feature so print jobs are only released with a 4-digit PIN. Guard against unauthorized access with secure, walk-up user authentication and Lightweight Directory Access Protocol (LDAP).
Dell S2825cdn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
700 - 3500 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, coated paper
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to application, scan to network, scan to FTP, scan to SMB, security lock slot
42.9 cm x 50.35 cm x 50 cm
31.7 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
700 - 3500 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, XPS, URF, PWG
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
12.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Speed Dialing
200 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
Bypass tray - 50 sheets , Input tray - 250 sheets , ADF - 50 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm (Letter A) - B/W , Printing: up to 30 ppm (Letter A) - colour , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 19 ppm (Letter A) - colour duplex , Copying: up to 30 ppm (Letter A) - B/W , Copying: up to 30 ppm (Letter A) - colour , Copying: up to 19 ppm (Letter A) - B/W duplex , Copying: up to 19 ppm (Letter A) - colour duplex , Scanning: up to 32 ppm (Letter A) - B/W , Scanning: up to 15 ppm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
TLS, IPsec, 802.1x, PEAPv0
Operating System Support
MS Windows Server 2008 R2, Ubuntu Linux 12.04, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.7 - 10.10
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
GS, ICES-003, NOM, SABS, EN 61000-3-3, EN55024, WHQL, EN55022 Class B, FCC Part 15 B, FCC Part 68, FCC Part 15 C, RoHS, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, Energy-Related Products (ErP) Lot 6, REACH, CAN/CSA C22.2 No. 60950-1-07, RCM, Energy-Related Products (ErP) Lot 4, DHHS 21CFR (J), EN 61000-3-2 Class A, ICASA
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
42.9 cm
50.35 cm
50 cm
31.7 kg
Shipping Width
58 cm
Shipping Depth
63.4 cm
Shipping Height
65.9 cm
Shipping Weight
36 kg
5 °C
32 °C
15 - 85% (non-condensing)
BTWW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
