Dell C3765DNF Colour Laser Printer
Quicklinx: 913FWS00 Mfr#: 210-40379
Empower your business to do more. The versatile Dell C3765dnf multifunction color laser printer offers value, quality and efficiency to medium and large workgroups.
  • Collaborate easily
    Scan, share, search and organize documents securely using Nuance PaperPort Pro 14.
  • Connect anywhere
    Manage documents conveniently with PaperPort Anywhere cloud service.
  • Save operating costs
    Convert your documents to electronic data to help increase efficiency and reduce paper expenses.
  • Get visible results in a flash
    Blaze through heavy-duty print and copy jobs at up to 36 ppm letter(in both mono and color) with ColorbyDell and Innovative Image Enhancement Algorithm.
  • Help ensure the safety of your data
    Work confidently with password protection, LDAP protocol and Kerberos authentication.
  • Take control
    Enjoy an intuitive operating panel with 4.3-inch color LCD touch display and one-touch Energy Saver mode activation.
  • Maximize your money
    Take advantage of low cost per page, with a separate replaceable toner cartridge and drum life of up to 60,000 pages each Cyan, Magenta, Yellow and Black.
  • Rely on high performance
    Handle high print volumes easily with a maximum duty cycle of up to 80,000 prints per month.
  • Expend less energy
    Cut consumption with fast-fusing EA Eco-Toner technology and sleep mode at the touch of the Energy Saver button. The N-Up feature is designed to let you print multiple pages on a single sheet of paper.
  • Catch costly waste before it can happen
    Monitor, track and manage color usage with Color Track Pro v1.1.
Dell C3765dnf - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 impressions
Recommended Monthly Volume
2400 pages
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Display
4.3"
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Print from USB flash drive, scan to application, scan to network
43.9 cm x 53 cm x 55.8 cm
32.6 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 impressions
2400 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
512 MB 512 MB
Copying
Max Copying Speed
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PCL 6 (XL 2.1), XPS, PDF 1.6
Automatic Duplexing
Colour Management Features
Application-based colour management
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
50 sheets
Max Media Size
A4/Legal
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 23 ppm - B/W duplex , Printing: up to 23 ppm - colour duplex , Printing: up to 36 ppm (Letter A) - B/W , Printing: up to 36 ppm (Letter A) - colour , Copying: up to 36 ppm (Letter A) - B/W , Copying: up to 36 ppm (Letter A) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
SNMP, HTTP
Security Protocols & Features
Kerberos, LDAP, SSL, TLS, IPsec, AES-256
Operating System Support
Novell NetWare, MS Windows XP, UNIX, MS Windows Server 2003, IBM AIX 5.1, IBM AIX 5.2, MS Windows 7, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), HP-UX 11i v2, MS Windows Server 2008, IBM AIX 5.3, Red Hat Enterprise Linux 5 Desktop, MS Windows Server 2008 R2, Apple Mac OS X 10.3.9 - 10.7, Oracle Solaris 9, IBM AIX 6
Software Included
Drivers & Utilities, Dell Toner Management System, Dell Printer Configuration Web Tool, Dell Private MIB 0.85, Dell ColorTrack Professional 1.1
Phone cable, fax terminator
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 3000 pages , 1 x toner cartridge (magenta) - up to 3000 pages , 1 x toner cartridge (yellow) - up to 3000 pages
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
43.9 cm
53 cm
55.8 cm
32.6 kg
913F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
