Dell C2665DNF Colour Networked Laser Printer
Quicklinx: 9DMWWS00 Mfr#: 210-ABWL
Collaborate and share documents easily with a smart, feature-rich printer offering single sign-on access to multiple cloud storage services with Dell document hub.
The world's smartest color multifunction printer is designed to be the central component of your digital document management system, enabling single sign-on access to multiple cloud storage services through an intuitive touch interface.
  • Increase collaboration with the world's smartest color multifunction printer
  • Print, scan and share with cloud connectivity
  • Easy to use and secure
    With a large capacitive touch screen that's easy to read and navigate, you can quickly access your personalized printer profile and commonly used functions on your printer.
  • Mobility redefined
    Discover simple ways to connect your compatible phone or tablet to your printer. Or, get access to personal settings on one printer from another printer.
Dell C2665dnf - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Max Copying Speed
Up to 27 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Display
4.3"
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, coated paper, heavy-weight paper, thick paper
Standard Media Capacity
400 sheets
Max Media Capacity
950 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AC 230 V (50/60Hz)
43.9 cm x 52.95 cm x 55.8 cm
32.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 27 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Up to 600 x 600 dpi
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, XPS
Automatic Duplexing
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
9600 x 9600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, remote reception, delayed sending, fax polling, poll receive
Document & Media Handling
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
400 sheets
Max Media Capacity
950 sheets
250 sheets
Speed Details
Printing: up to 27 ppm (A4) - B/W , Printing: up to 27 ppm (A4) - colour , Printing: up to 18 ppm (A4) - B/W duplex , Printing: up to 18 ppm (A4) - colour duplex , Printing: up to 28 ppm (Letter A) - B/W , Printing: up to 28 ppm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type A , 1 x USB host - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Operating System Support
Novell NetWare, MS Windows XP, MS Windows Server 2003, Apple Mac OS X 10.5, MS Windows 7, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Red Hat Enterprise Linux 5, Red Hat Enterprise Linux 6, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows RT, Windows 8 64-bit
AC 230 V (50/60Hz)
63 Watt
Power Consumption Standby
14.5 Watt
Power Consumption Sleep
3.5 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
20 sec
GS, RoHS, WEEE, Energy-Related Products (ErP) Lot 6
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - response time: next business day
43.9 cm
52.95 cm
55.8 cm
32.6 kg
Shipping Width
57 cm
Shipping Depth
68.6 cm
Shipping Height
70.6 cm
Shipping Weight
37.5 kg
10 °C
32 °C
10 - 85% (non-condensing)
