Dell 2355dn Mono Laser Multifunction Printer
Quicklinx: 7LWWWS00 Mfr#: 210-34529
Multitasking made simple
Take on your daily office tasks with confidence with the DellTM 2355dn Multifunction Laser Printer, which can print, copy, scan and fax. Your entire office or workgroup can save space by using only one easily networked machine instead of four.
-Print fast at speeds up to 33 A4-sized pages per minute (actual print speed will vary with use)
-Program daily tasks and manage print jobs with the 10.9cm (4.3")colour LCD touch screen
-Enjoy quality printouts with 600x600 dpi print resolution
-Print many pages with standard 3,000-page black toner1 and an 80,000 maximum monthly duty cycle
-Easily connect to your office with on-board networking options
Contents in the box:
Dell 2355dn Multifunction Laser Printer
Installation software and manuals CD (Printer driver, other included software in multiple languages)
Dell 2355dn standard black toner cartridge (3000 page yield2)
Setup placemat
Hardware recycle program label and instructions
Power Cord
2-pin or 4-pin Telephone Cable RJ11
Dummy Plug inserted into printer
BAM techsheet
Recycle letter from Michael Dell
Printer Type
Networked multifunction laser printer
Printer Dimensions (W x D x H)
465 mm W x 445 mm D x 460 mm H (18.3" x 17.5" x 18.1")
Printer Weight
(20.2 kg)
Max Print Speed (Actual print speed will vary with use)
Up to 33 ppm A4
Print Resolution
600 X 600, 1200 dpi
Maximum Monthly Duty Cycle
Up to 80,000 pages per month
Standard Paper Input
250 sheets + 50 Sheet Multipurpose tray
360MHz
Standard Memory 256 MB
Expansion Slots
one slot
Maximum Paper Input Capacity
550-sheets
Standard/Maximum Output Capacity
150-sheet
Optional Paper Input Accessories
Optional 250 sheet additional drawer available
Duplex (Two-sided printing)
Yes (standard)
Media Types Supported
Plain, Thin, Recycled, LetterHead ; Cardstock, Labels, Transparency, Bond, Preprinted, Coloured, Envelope, Recycled, Thick, Thin,LetterHead.
Paper Weights Supported
Multipurpose tray: 60-90 g/m2
Standard Interfaces (Cables not included)
USB2.0 High speed supported (Type-B connector) ; Ethernet 10/100 BaseT RJ-45 port ; RJ-11 telephone and fax port
Printer Language
PCL® 5e, PCL 6 and PostScript® Level 3 Emulation.
Compatible Client Operating Systems
Windows Vista® 32bit/64bit (Home Basic, Home Premium, Ultimate, Business), Windows Server 2008 64bit, Windows XP 32bit/64bit (Home & Pro), Windows 2003 Server 32bit/64bit, Microsoft® Windows® 7 32bit/64bit, Windows 2000, Various Linux OS, Mac OS® 10.3 ~ 10.6, Novell NetWare NDPS services via TCP/IP & IPP on 5.x, 6.x, Bonjour discovery supported, SAP R/3 v4.6C, 4.x and 3.x and later, Citrix MetaFrame, Citrix 4.0/4.5/5.0 (XenApps); Windows Terminal Services
Printer Management Software
SmartThru Office2, Dell Scan Manager, Dell Toner Management System, Dell Printer Status Monitor, Printer Setting Utility, Set IP Address Utility, Firmware Upgrade Utility, Dell Printer Configuration Web Tool (EWS)
