52-Port Gigabit Layer 2 Managed Switch including 4 x 10GE SFP+ ports. The DGS-3000 Series Gigabit L2 Managed Switches feature a variety of ports, including 10/100/1000BASE-T RJ-45 ports, 1G SFP ports, and 10G SFP+ ports for increased network bandwidth. Surge protection, advanced Layer 2 functions, and a suite of security and management tools make the DGS-3000 Series Gigabit L2 Managed Switches ideal for Metro Ethernet and campus applications.
Robust performance
With a switching capacity of 176 Gbps and forwarding performance of 130.95 Mpps, this switch is designed to handle intensive data traffic, ensuring smooth and efficient network operations. -
Comprehensive connectivity
Equipped with 48 10/100/1000 ports and 4 10Gb Ethernet SFP+ ports, the D-Link DGS 3000-52X offers a wide range of connection options for various networking needs, supporting both high-speed and legacy devices. -
Advanced network security
Features such as ARP support, DoS attack prevention, Extensive Access Control List (ACL) support, and D-Link's Safeguard Engine provide a secure networking environment, protecting against external threats and unauthorized access. -
Efficient network management
Support for SNMP, RMON, SSH, and Telnet allows for flexible and comprehensive remote management, enabling efficient monitoring and control of network resources. -
Enhanced durability
With a MTBF of 465,240 hours, 6 kV Surge protection, and a robust design featuring 2 fans, this switch is built to withstand demanding operational environments, ensuring long-term reliability and performance.
- D-Link DGS 3000-52X - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10Gb Ethernet SFP+
- Performance
- Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH
- Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, Dying Gasp support, QoS, Safeguard Engine, NAP, LLDP support, RSPAN, CoS, D-Link SIM, ERPS, 2 fans, 3MB packet buffer, 6KV Surge protection, VLAN mirroring, WAC, CFM, Extensive ACL support, Guest VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 21 cm x 4.4 cm
- 2.4 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 16K entries
- Status Indicators
- Power, RPS (Redundant Power Supply), fan, console, link/activity/speed
- 48 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management
- Power Device
- Internal power supply
- Voltage Required
- 40.7 Watt
- Included Accessories
- 4 rubber feet
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 465,240 hours
- VCCI, C-Tick, BSMI, cUL, IEC 61000-4-5, CB, FCC, ITU-T G.8032
- 44 cm
- 21 cm
- 4.4 cm
- 2.4 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
