The DAP-3410 is a Wireless N 5GHz Outdoor Access Point. It can be deployed to expand the coverage and signal strength of an existing wireless network or alternatively used as a low cost alternative to connect networks that are not joined physically by an Ethernet or fiber cable. Within PoE integrated as standard, the DAP-3410 is built to withstand harsh outdoor deployments.
Increased network connectivity and throughput
Expand current wireless network capacity with the latest 5 GHz 802.11a/n wireless connectivity. In addition, two 10/100 Ethernet ports (one supporting PoE) allow for further physical expansion using traditional wired medium. The built-in 10 dBi sector antenna has a high power output ensuring that wireless coverage will cover even hard to reach locations. Whether you want to connect additional wireless devices such as smartphones or laptops, or bringing connectivity to networks separated by short distances, the DAP-3410 has it covered. -
Fine-tuned control over network resources
The DAP-3410 supports up to 8 SSIDs, allowing the administrators to logically divide the access point into several virtual access points all within a single hardware platform. Rather than having separate networks with several access points, administrators can deploy one single AP to support more than one application, such as public Internet access and internal network control to increase flexibility and keep costs down. The DAP-3410 supports 802.1Q VLAN tagging, operating with multiple SSIDs to segment traffic to enhance performance and security. -
Robust security and management tools
The DAP-3410 supports 64/128-bit WEP data encryption and WPA/WPA2 security functions. In addition, it provides MAC address filtering to control user access, and the disable SSID broadcast function to limit outsiders' access to the internal network. -
Power over Ethernet (PoE)
The DAP-3410 is powered by PoE5 which allows for convenient installation, especially in places where a power supply is not reliable or power cables are not available or easily set up. Also, the DAP-3410 can supply power to a connected D-Link surveillance camera through PoE.
- D-Link DAP-3410 - wireless bridge - Wi-Fi
- Wireless bridge
- Form Factor
- External - outdoor
- Data Link Protocol
- IEEE 802.11a, IEEE 802.11n
- Frequency Band
- 5 GHz
- Capacity
- VLANs supported: 8
- Power Over Ethernet (PoE) Supported
- PoE
- 9.6 cm x 4.8 cm x 16.5 cm
- 350 g
- Wireless bridge
- Ruggedized Design
- Outdoor
- 9.6 cm
- 4.8 cm
- 16.5 cm
- 350 g
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS
- Frequency Band
- 5 GHz
- Capacity
- Status Indicators
- Power, signal strength, LAN
- Power over Ethernet (PoE), MAC address filtering, wall mountable
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- IEEE 802.3, IEEE 802.3u, IEEE 802.11a, IEEE 802.1x, IEEE 802.11n
Aerial
- Antenna
- Internal
- Gain Level
- 15 dBi
- 1 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45
- FCC
- PoE
- -20 °C
- 60 °C
- 0 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
