D-Link Outdoor Industrial AC1200 Access Point
Quicklinx: J7MMWS00 Mfr#: DIS-3650AP
£537.22 ex VAT
£644.66 inc VAT
The D-Link DIS-3650AP wireless access point is designed to meet the demands of modern networks, offering secure and reliable wireless connectivity. With support for Wi-Fi 5 and 2x2 MU-MIMO technology, it ensures efficient communication between multiple devices simultaneously. This device is equipped with comprehensive encryption standards, including WPA and WPA2, to protect against unauthorized access and ensure your network's integrity. Its versatile form factor allows for wall or DIN rail mounting, providing flexibility in deployment across various environments. Additionally, the DIS-3650AP's support for Power over Ethernet (PoE) simplifies installation by allowing power and data transmission over a single cable. Whether for business or industrial use, the D-Link DIS-3650AP is engineered to deliver reliable performance, supporting maximum data rates of 300 Mbps on the 2.4 GHz band and 866 Mbps on the 5 GHz band, making it a suitable solution for high-bandwidth applications.
  • Enhanced connectivity
    Equipped with dual-band Wi-Fi 5 and 2x2 MU-MIMO technology, the D-Link DIS-3650AP ensures a robust and efficient wireless connection, allowing multiple devices to communicate simultaneously without compromising speed or quality.
  • Secure and reliable
    This wireless access point comes with comprehensive encryption standards including 128-bit WEP, 64-bit WEP, WPA, and WPA2, ensuring your network remains secure against unauthorized access and threats.
  • Versatile installation options
    With its wall and DIN rail mountable form factor, the DIS-3650AP offers flexible installation options, making it a suitable choice for various environments, from offices to industrial settings.
  • Efficient operation
    Support for Power over Ethernet (PoE) enables the DIS-3650AP to receive power and data over a single Ethernet cable, simplifying deployment and reducing cable clutter.
  • Optimized performance
    The device supports a maximum data rate of 300 Mbps on the 2.4 GHz band and 866 Mbps on the 5 GHz band, catering to the demands of high-bandwidth applications and ensuring smooth, uninterrupted connectivity.
D-Link DIS-3650AP - radio access point - Wi-Fi 5
Radio access point
Wall / DIN rail mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
Power Over Ethernet (PoE) Supported
PoE
22.046 cm x 7.254 cm x 12.746 cm
1069.6 g
Radio access point
22.046 cm
7.254 cm
12.746 cm
1069.6 g
Network / Transport Protocol
HTTP
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AC1200
Fast Roaming, 2x2 MU-MIMO technology, HotSpot 2.0
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
External
Antenna Qty
2
1 x Ethernet 1000 (PoE) - RJ-45 , 1 x console - RJ-45
FCC, LVD
PoE
-20 °C
65 °C
10 - 90% (non-condensing)
Brand: D-Link
Price Range Ex VAT: £500 - £750
