D-Link Wireless AC1200 Wave2 Dual-Band Industrial Access Point
Quicklinx: J7MLWS00 Mfr#: DIS-2650AP
  • IEEE 802.11n
£417.31 ex VAT
£500.77 inc VAT
The DIS-2650AP industrial AC1200 Wave 2 access point is designed specifically to operate in harsh environments with a wide operating temperature range and surge/ESD protection. It comes in a sturdy metal housing that can be DIN- or wall-mounted, ideal for industrial installations.
  • Versatile connectivity
    Equipped with two Gigabit Ethernet (PoE) ports and one console port, the DIS-2650AP offers flexible connection options for a variety of networking needs, ensuring reliable and efficient communication.
  • Robust security
    Featuring a comprehensive suite of encryption algorithms including 128-bit WEP, 64-bit WEP, WPA, and WPA2, the DIS-2650AP provides a secure wireless network environment, safeguarding sensitive data from potential threats.
  • Efficient operation
    With support for ENERGY STAR and a fanless design, this wireless access point operates efficiently, reducing energy consumption while maintaining a quiet operational environment.
  • Advanced wireless capabilities
    Supporting IEEE 802.11ac Wave 2 along with other Wi-Fi standards, the DIS-2650AP delivers high-speed Wi-Fi connectivity across the 2.4 GHz and 5 GHz bands, accommodating a wide range of devices and ensuring optimal network performance.
  • Durable and adaptable design
    Designed for wall or DIN rail mounting, the DIS-2650AP is built to withstand harsh environments, with an operating temperature range from -20°C to 65°C, making it suitable for a variety of industrial applications.
D-Link DIS-2650AP - radio access point - Wi-Fi 5
Radio access point
Wall / DIN rail mountable
Ports Qty
2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
Power Over Ethernet (PoE) Supported
PoE
DC 12 - 48 V
19.62 cm x 10.59 cm x 4 cm
785 g
Radio access point
19.62 cm
10.59 cm
4 cm
785 g
Ports Qty
2
Wireless
Network / Transport Protocol
HTTP
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AC1200
Power over Ethernet (PoE), fanless, Traffic Control, Energy-Efficient Ethernet (EEE), HotSpot 2.0
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3at, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 2
Aerial
Antenna
External
Antenna Qty
2
2 x Ethernet 1000 (PoE) - RJ-45 , 1 x console - RJ-45
BSMI, FCC, RoHS, WEEE, LVD, NCC
PoE
DC 12 - 48 V
14.478 watt
-20 °C
65 °C
10 - 90% RH (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: D-Link
