The DAP-2230 Wireless N PoE Access Point allows businesses to create a secure and manageable wireless network. Multiple operational modes, network management tools and security features gives network administrators more flexible deployment options. The DAP-2230 can be ceiling mounted, wall mounted or placed on a desktop to meet any wireless demands.
Faster wireless networking
The DAP-2230 provides an up to 300 Mbps wireless connection with other 802.11n wireless clients. This capability allows users to participate in real-time activities online, such as video streaming, online gaming, and real-time audio. -
Four different operation modes
Capable of operating in one of four different operation modes to meet your wireless networking needs: Access Point, WDS with AP, WDS, and Wireless Client. -
Power over Ethernet
The DAP-2230 supports IEEE 802.3af PoE (Power over Ethernet) which enables it to be supplied with power over an Ethernet cable or IEEE 802.3af PoE switch. -
Convenient installation
The DAP-2230 features a wall mount in the rear for easy setup on walls.
- D-Link DAP-2230 Wireless N PoE Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Included Accessories
- Wall mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- 12.9 cm x 12.9 cm x 2.9 cm
- 101.4 g
- 12.9 cm
- 12.9 cm
- 2.9 cm
- 101.4 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- SMTP, DHCP
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- Frequency Band
- 2.4 GHz
- Status Indicators
- Status
- LDAP support, MAC address filtering, Wireless Distribution System (WDS) support, reset button, Wireless Client Mode, Traffic Control, security lock slot (cable lock sold separately)
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, SSL, TLS, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), LDAP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- Internal
- Gain Level
- 3 dBi
- 1 x 100Base-TX (PoE) - RJ-45
- Wall mounting kit
- UL, IC, FCC, TLS
- PoE
- Power Device
- External power adapter
- 16.8 Watt
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
