Cyberpower Pro 1500VA Tower UPS
Quicklinx: BBTRWS00 Mfr#: PR1500ELCD
The Professional Tower PR1500ELCD UPS with LCD control panel and pure sine wave output is Active PFC compatible, safeguarding mission-critical servers, telecom equipment, VoIP and internetworking hardware that requires seamless connection and advanced power protection. Featuring Automatic Voltage Regulation (AVR) technology that helps to stabilize AC voltage and to provide protection to connected equipment. This UPS system is ENERGY STAR® qualified and designed with patented GreenPower UPS™ bypass circuitry that improves the operating efficiency so that users can enjoy significant cost savings by reducing energy consumption and waste heat generated.
The LCD control panel provides 41 different settings for status and operation. Functions include menus for checking power status on (11) different parameters, (23) settings for setup and control of the UPS, (3) battery test & calibration options, and (4) selections in the Log menu. With its attached cable the LCD control panel can be removed from the UPS and relocated up to 4.5 feet away from the UPS for ease of use regardless of locations.
The PR1500ELCD comes with a capacity of 1500VA/1350Watts, eight (8) IEC C13 receptacles, and two (2) hot-swappable, user-replaceable 12V/17Ah batteries. The EMI/RFI filters increase the tolerance of noises and load interferences so that improve the picture and sound quality in audio/video systems. The unit offers one (1) HID USB and one (1) Serial connectivity port with PC and one (1) Emergency Power Off (EPO) port for the capability to immediately power down entire installed equipment from a single access point.
The PR1500ELCD features remote network management capabilities which include the PowerPanel® Business Edition software, an optional SNMP/ HTTP remote management card, and an optional ENVIROSENSOR. These management tools enable administrators to perform various operations including remote management, real-time monitoring, UPS configuration, and scheduled server/workstations shutdowns. All Smart App UPS systems and Remote Management Card have achieved the status of Cisco EnergyWise certified, better supporting other EnergyWise-enabled entities and be easily monitored and controlled to achieve the best energy performance under the EnergyWise operation framework.
For as long as you own this product, CyberPower will cover up to $100,000 of properly connected equipment if it's ever damaged by a surge, including surges due to lightning strikes.
CyberPower Professional Series PR1500ELCD - UPS - 1350 Watt - 1500 VA
UPS - external
25.1 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
1350 Watt / 1500 VA
Input Connectors
Power IEC 60320 C14
- 17 Ah
Batteries Qty
2
Run Time (Up To)
5 min at full load
RS-232, USB
17 cm x 43.2 cm x 22.1 cm
3-year warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
47 - 63 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
1350 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker, electronic current limit
Quantity
2
Voltage Provided
12 V
17 Ah
Run Time (Up To)
5 min at full load , 17 min at half load
Recharge Time
8 hours
Remote Management Interface
RS-232, USB
Equipment Protection Value
10000 Euros
Audible alarm, Automatic Voltage Regulation (AVR), GreenPower UPS Technology
Software Included
PowerPanel Business Edition
Limited warranty - batteries - 3 years
17 cm
43.2 cm
22.1 cm
25.1 kg
