CyberPower Office Rackmount Series OR1500ELCDRM1U UPS 900 Watt 1500 VA
Quicklinx: C1BGWS00 Mfr#: OR1500ELCDRM1U
Office Rackmount Series UPS is the most high-performace UPS for servers, networking equipment, workstations and other mission-critical applications. With Automatic Voltage Regulator (AVR) stabilizing the AC input to prevent power interruption, sine-wave output provides assurance of compatibility with all types of loads. Office Rack Mount Series UPS provides you clean and consistent power, it's the most reliable UPS to bring you the best quality power. With GreenPower UPS technology, Office Rack Mount Series UPS can save up to 75% of electricity and save your electricity bill.
CyberPower Office Rackmount Series OR1500ELCDRM1U - UPS - 900 Watt - 1500 VA
UPS - rack-mountable
Rack Size
1U
19.4 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 10%
Power Capacity
900 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x IEC connector (UPS and surge) , 2 x IEC connector (surge)
Lead Acid - 9 Ah
Batteries Qty
4
Run Time (Up To)
3 min at full load
RS-232, USB
Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2008
43.3 cm x 49.5 cm x 4.4 cm
Height (Rack Units)
1U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 265 V
Frequency Provided
50/60 Hz
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V ± 10% - 50/60 Hz
Power Capacity
900 Watt / 1500 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Circuit Protection
Circuit breaker
Quantity
4
Lead Acid
Voltage Provided
6 V
9 Ah
Run Time (Up To)
3 min at full load , 11 min at half load
Recharge Time
8 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B
Phone cable - external , USB cable - external
Equipment Protection Value
100000 Euros
Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
PCT, RoHS
Software Included
PowerPanel Business Edition
0 - 95%
43.3 cm
49.5 cm
4.4 cm
19.4 kg
