Corsair RMx series power supplies give you extremely tight voltage control, quiet operation, Gold-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Gold efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. And, the fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
80 PLUS Gold certified
Gold certification ensures high efficiency operation for less excess heat and lower operating costs. -
Premium internal components ensure solid power delivery and long term reliability. -
Zero RPM fan mode
Since the fan doesn't turn on until it's needed, you'll enjoy virtually silent operation at low and medium loads. -
Fully modular cable set
Installation is faster, since you can mount the power supply in the case first, and then attach only the cables you need.
- CORSAIR RMx Series RM750x - power supply - 750 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 1.94 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 4 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties
- White
- 15 cm x 18 cm x 8.6 cm
- 10 years warranty
- PSU Form Factor
- ATX
- White
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 62.5 A , -12V - 0.8 A , +5VSB - 3 A
- Efficiency
- 90%
- 80 PLUS Gold
- Cable ties
- Cables Included
- Power cable kit
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, rifle bearing cooling fan, fully modular
- CSA, UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU-TR
- Limited warranty - 10 years
- 15 cm
- 18 cm
- 8.6 cm
- 1.94 kg
