Corsair 750 Watt Pro Series Gold AX750
Quicklinx: 71HLWS00 Mfr#: CMPSU-750AXUK
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you.
With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus Gold seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery.
  • A fully modular cabling system
    All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling - the cables stay in place and connect to your fully-modular Corsair power supply.
  • Incredible efficiency
CORSAIR Professional Series Gold AX750 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
3.3 kg
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 62 A , -12V - 0.5 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 12 x 15 pin Serial ATA power , 8 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
120 mm fan
15 cm x 16 cm x 8.6 cm
7 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
80 PLUS Gold
Power cable kit
MTBF
100,000 hours
Cooling System
120 mm fan
Over current protection, over voltage protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, fully modular
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC
Limited warranty - 7 years
15 cm
16 cm
8.6 cm
3.3 kg
Shipping Width
39.1 cm
Shipping Depth
15.1 cm
Shipping Height
22.5 cm
Shipping Weight
4 kg
