Corsair 650W Enthusiast Series TX650 Modular Power Supply
Quicklinx: 7LGKWS00 Mfr#: CP-9020039-UK
Based on the Enthusiast Series TX V2 line, Enthusiast Series Modular PSUs add a modular cabling system for improved installation flexibility. It provides a great combination of exacting performance standards and affordability.
  • Cable-ready
    The modular cabling system includes a complete set of flat, detachable cables that allow you to use only the ones you need. This allows you to reduce clutter for a clean-looking system with improved airflow. The attached ATX cable is fully-sleeved for superior protection. And, all cables are extra long to support full-tower PC systems.
  • 80 PLUS bronze certification for smart, efficient power delivery
    80 PLUS bronze is your guarantee that your Enthusiast Series Modular power supply will deliver 85% efficiency or higher at 50% load. Superior efficiency is essential in a high performance power supply - it runs quieter, generates minimal excess heat, and saves you money every month.
  • Ready to take the heat
    Enthusiast Series Modular is designed for reliable operation in high-performance PCs where clean, stable power is important. It's rated for full, continuous power delivery at an ambient temperature. The ultra-quiet, double ball-bearing fan delivers excellent airflow with exceptionally
  • Critical protection for your components
    Adherence to exacting performance standards for voltage regulation helps protect your high-performance gear. Exceptionally clean power output with low ripple and noise and multiple protection mechanisms gives you the confidence you need.
CORSAIR Enthusiast Series Modular TX650M - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
2.54 kg
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 30 A , +5V - 30 A , +12V - 54 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V , 8 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
140 mm fan
Cable ties, mounting kit
15 cm x 16 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
140 mm fan
Over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, semi-modular
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus, ErP Ready
Limited warranty - 5 years
15 cm
16 cm
8.6 cm
2.54 kg
Shipping Width
29.3 cm
Shipping Depth
21.5 cm
Shipping Height
13.5 cm
Shipping Weight
2.94 kg
