Product
Brand
Compaq Modular Power Distribution Unt
Quicklinx: 2J4FWS00 Mfr#: 252663-B24
Is your data center lacking sufficient outlet receptacles or flexibility in rack space? Is cable management a problem? HP Modular PDUs have a unique architecture designed specifically for data center customers who want to maximize power distribution and space efficiencies in the rack. Available in a small form factor with flexible mounting options, installation is quick and easy with all brackets, accessories and installation guides included. Modular PDUs consist of two building blocks the Core Unit (core) and the Extension Bar(s) (sticks). The Core Unit is 1U/0U, and the Extension Bars mount directly to the frame of the rack in multiple locations. Single phase models are available up to 40 amps and can have up to 28 outlets divided across 4 extension bars. Three phase models are core only units with 6 x C19 outlets that can be connected to optional extension bars or directly to components such as BladeSystems enclosures.
HPE - power distribution strip - 3680 VA
Power distribution strip - rack-mountable
8.2 kg
Input Voltage
AC 200/240 V
Power Capacity
3680 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
16 x power IEC 60320 C13
44.5 cm x 14.2 cm x 4.1 cm
3 years warranty
HPE 10XXX G2; BladeSystem bc1000; Enterprise Modular Library 71e LTO-4; ProLiant DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 G6, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML310e Gen8, ML350e Gen8, Moonshot Server, Moonshot Server Starter System, SL250s Gen8, SL270s Gen8, SL390s G7; Rack
Input Voltage
AC 200/240 V
Frequency Required
50/60 Hz
Input Connectors
Power Capacity
3680 VA
Circuit Protection
Circuit breaker
4 x power cable - external
Rack Mounting Kit
Included
UL, cUL, NOM
Limited warranty - 3 years
10 °C
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
10 - 90%
Humidity Range Storage
5 - 95%
44.5 cm
14.2 cm
4.1 cm
8.2 kg
HP UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, R7000 , HPE 10642 G2 1200mm deep Shock Rack, 10647 G2 1200mm deep Shock Rack , HPE BladeSystem bc1000 Blade PC , HPE Enterprise Modular Library 71e LTO-4 Ultrium 1840 , HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL360 G7 Special Server, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL380 G6, DL380 G7 Special Server, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL580 G5 Highly Serviceable Tower, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML370 G6 Special Server, Moonshot Server, Moonshot Server Starter System, SL170s G6 Base Left Half Width tray, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL390s G7 2U Left Half Tray Node Server, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Base 4U Right Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray , HPE Rack
