Cisco Wireless-G Access Point with POE & RangeBooster
Quicklinx: 4J5DWS00 Mfr#: WAP200-UK
Add PCs to your network with no cabling hassle. Cisco Small Business WAP200 Access Point enables the addition of Wireless-G (802.11g) device to your network without so much as a power plug.
The WAP200's RangeBooster technology doubles the reach and reduces the "dead spots" of a standard Wireless-G connection. Power over Ethernet (PoE) removes the necessity to locate the access point near an electrical outlet. Support for WEP, WPA, and WPA2 security protocols with up to 256-bit encryption, as well as new Wireless Security Monitoring functionality, provides advanced security.
Cisco Small Business WAP200 - radio access point - Wi-Fi
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
17 cm x 19.5 cm x 20.5 cm
400 g
Radio access point
17 cm
19.5 cm
20.5 cm
400 g
United Kingdom
External
Wireless
Data Transfer Rate
54 Mbps
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz
Status Indicators
Port status, power
Auto-sensing per device, DHCP support, power over Ethernet (PoE), load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, E-mail alert, half duplex mode, full duplex mode, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RangeBooster technology
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11f
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
2 dBi
1 x 100Base-TX (PoE) - RJ-45
1 x network cable
ICES-003, FCC
PoE
External power adapter
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
