Cisco VG204XM Analog Voice Gateway
Quicklinx: 9TCWWS00 Mfr#: VG204XM
The Cisco VG204XM Analog Voice Gateways allow you to use your IP telephony solution with traditional analog devices while taking advantage of the productivity afforded by IP infrastructure.
The Cisco VG204XM is ideal for analog phone deployments ranging from centralized to sparsely concentrated or distributed topologies. These analog voice gateways provide a high level of availability at locations with MGCP fallback, with ease of manageability using Cisco IOS software monitoring features. They offer many supplementary analog calling features depending on the call control and signaling type used.
  • Cisco IOS software-based hardware
    The hardware includes uniform Cisco command-line interface (CLI) and Simple Network Management Protocol Version 3 (SNMPv3) support for ease of gateway configuration and operation.
  • Robust voice quality
    Cisco experience in providing toll-quality packet-voice service helps ensure that the Cisco VG204XM provides the clear, robust voice quality end users have come to expect from telephony services.
  • Investment protection
    You can continue to use your existing analog phones, fax machines, and modems while taking advantage of IP telephony. Basic analog phone connectivity is needed when the infrastructure (wiring) or application does not support or require IP phones. The Cisco VG204XM is ideal platforms to support sparsely concentrated, distributed analog phone deployments. Thus you can deploy IP telephony without having to purchase IP phones for all users and you can continue using existing devices.
  • High availability
    With these gateways you will experience less voice downtime due to WAN link failure. The Cisco VG204XM has built-in Media Gateway Control Protocol (MGCP) failover to an H.323 connection to a Survivable Remote Site Telephony (SRST) router.
  • Reduced barrier to entry
    These analog phone gateways provide a low-cost alternative for low-end analog phones and allow you to take advantage of IP telephony with a lower overall IP telephony investment.
Cisco VG204XM Analog Voice Gateway - VoIP phone adapter
VoIP phone adapter
External
RAM
256 MB
Flash Memory
128 MB
Ethernet, Fast Ethernet
VoIP Protocols
MGCP, SCCP, SIP, H.323 v4, RTP, SRTP
Telephony Interfaces
4 phone (FXS)
22.38 cm x 20.65 cm x 4.52 cm
1.351 kg
VoIP phone adapter
22.38 cm
20.65 cm
4.52 cm
1.351 kg
Processor / Memory / Storage
RAM
256 MB DDR2 SDRAM
Flash Memory
128 MB
External
Wired
Network / Transport Protocol
DHCP, DNS
Routing Protocol
HSRP
Remote Management Protocol
Telnet, SNMP 3, HTTP, TFTP, CLI
Wall mountable, RADIUS support
Authentication Method
RADIUS, TACACS+
IP Telephony
VoIP Protocols
Voice Codecs
G.711, G.729a, T.38
4 phone (FXS)
IP Telephony Features
Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer
2 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 1 x management , 4 x modem - RJ-11
MTBF
200,000 hours
CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 60950-1, AS/NZS 60950, CAN/CSA C22.2 No. 60950, VCCI Class B, EN 300 386
External power adapter
30 Watt
10 - 85% (non-condensing)
9TCW C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9TCW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.78
9TCW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
