Cisco UC System with 2BRI, 2VIC Exp.
Quicklinx: 7L3XWS00 Mfr#: UC560-BRI-K9
For small business employees to communicate effectively with suppliers and customers in today's competitive business environment, they need ready access to information, updated in real time. They also need to stay connected - to each other and to the business applications they use to do their jobs. With the right solution, your business can collaborate more effectively and problem-solve like never before.
The Cisco Unified Communications 560, a central part of the Cisco Smart Business Communications System (SBCS), is an affordable unified communications appliance that provides voice and data communications, voicemail, automated attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, email, and customer relationship management (CRM) programs. This easy-to-use solution supports up to 104 users and provides flexible deployment options based on your needs, supporting a wide array of IP phones, public switched telephone network (PSTN) interfaces, and Internet connectivity.
  • Versatile connectivity
    With support for Ethernet, Fast Ethernet, and Gigabit Ethernet, the Cisco 560 ensures high-speed connectivity for various network needs, making it a suitable choice for businesses looking to maintain robust, reliable connections.
  • Comprehensive telephony support
    The device's capability to interface with 4 phone (FXS) connections alongside VoIP support makes it a comprehensive solution for businesses seeking to integrate their telephony systems seamlessly with their network infrastructure.
  • Expandable design
    Featuring two expansion slots and support for CompactFlash Card, the Cisco 560 offers businesses the flexibility to enhance their system's capabilities as their needs evolve, ensuring a durable investment.
Cisco Unified Communications 560 - VoIP gateway
VoIP gateway
Licence Qty
24 users
External - 2U
Telephony Interfaces
4 phone (FXS), 2 line (ISDN BRI)
44.5 cm x 35.6 cm x 8.9 cm
6.6 kg
1-year warranty
VoIP gateway
Height (Rack Units)
2U
Installed Modules Qty (Max)
0 (2)
44.5 cm
35.6 cm
8.9 cm
6.6 kg
External
Wired
Status Indicators
Port status, system
IP Telephony
Communications
Supported Flash Memory Cards
CompactFlash Card
Expansion Slots
2 (total) / 2 (free) x VIC
2 x modem , 4 x modem - RJ-11 , 3 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x management - RJ-45 , 1 x audio
1 x network cable , 1 x serial cable
Rack Mounting Kit
Included
Internal power supply
Limited warranty - 1 year
